Old 10-01-2012, 07:24 AM   #1
shift_down
shift_down is an unknown quantity at this point
SUPER Lean, cant figure it out
Hello everybody.
Ok, so at idle I am at 18-20 afr and it is scaring me a bit. If I tap the gas, afrs go down to 11-13 and when I am at WOT the afrs are at around 10-10.5. As soon as I let go of the peddle after WOT, the afrs jump up to 22/full lean and the car drops down to around 500 rpm and acts like it wants to stall.
My question is, what would make the car be so lean at idle, and why would it go full lean after WOT?
1. My bov is recirculated
2. Enthalpy Tune
3. Z32 MAF wired in correctly
Thanks for the help
shift_down is offline   Reply With Quote
Old 10-01-2012, 07:39 AM   #2
Synergy
Synergy is an unknown quantity at this point
Originally Posted by shift_down View Post
Hello everybody.
2. Enthalpy Tune
Thanks for the help
Its normal dont worry about it. Off the gas and at idle it pumps alot of air and very little gas. My wideband goes from 6-20 i believe and I know when i get off the gas mine says LEAAAAAAAAN. Perfectly normal.
Synergy is offline   Reply With Quote
Old 10-01-2012, 07:42 AM   #3
shift_down
Really? Because I know a few people that are 15afr at idle and after WOT. Why is my setup different? The car runs nice and healthy, but the numbers are whats scary.
Ka24 t3/t04b + Z32MAF + 550 subys + Walbro 255 + enthalpy Tune + 91 octane
Old 10-01-2012, 11:01 AM   #4
cotbu
cotbu's Avatar
Full lean after wot is normal.
But everything else you're describing is not, The 18-20afr idle and even more so the 10-10.5 wot afr. I'm assuming this is not an e85 setup correct?
Give ups the dough, You need a retune!
or you can go, pull codes, check for boost/vacuum leaks, then timing and see what happens.
Also
Old 10-01-2012, 11:10 AM   #5
shift_down
91 octane pump gas.
I think the WOT afrs are good. It should be rich under WOT, but the idle is scary.
Im going to check for codes and do a boost leak test and see what happens.
Old 10-01-2012, 08:46 PM   #6
cotbu
cotbu's Avatar
Too rich of an AFR should concern you, as well!
You can look up why, later I guess?!
Old 10-01-2012, 08:51 PM   #7
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
washes the oil off the cylinder wall, creates carbon build up on the piston
Old 10-01-2012, 09:55 PM   #8
shift_down
10afr under WOT on a turbod ka24de is not a concern. silly zilvians :P
Old 10-01-2012, 10:15 PM   #9
Synergy
10:1 is stupid rich if it doesnt hurt your motor your getting bad gas mileage bad power and lots of unburned HC and lots of carbon buildup.
AKA NOT GOOD.
Old 10-01-2012, 10:20 PM   #10
shift_down
Yes yes, my bad. I know it is bad to constantly run like this, for sure. I am saying it is not a concern to me at the moment. I have the car on jack stands while revving it up and monitoring.
Old 10-01-2012, 10:23 PM   #11
shift_down
I emailed enthalpy but he hasnt replied. I cant think of anything else causig this but the tune
