Old 03-12-2004, 04:33 PM   #1
jtt220
jtt220 has a little shameless behavior in the past
Send a message via AIM to jtt220
SR rb25dett turbo on a sr20det
Is this a direct swap (One turbo from a R32 GTR on a redtop sr20det), or would I need a custom downpipe? Anything else needed? Thanks in advance!
s13 hatch...all suspension baby!!
jtt220 is offline   Reply With Quote
Old 03-12-2004, 06:03 PM   #2
Burmonster
Burmonster's Avatar
Burmonster is making a name for him/her selfBurmonster is making a name for him/her self
Send a message via AIM to Burmonster
Its an RB26DETT not RB25, the RB25DET comes with only one turbo......unless you just hit the "t" key twice by accident.
Let me make sure I got this right, your are just taking about swapping the turbo right, not the entire engine?
If its just the turbo, it should be a pretty straight forward conversion. Refer to the list I provide below for # of bolts on the flange and etc.
GARRETT T25
They are from the small series of turbochargers specifically engineered for original-equipment small-capacity engines, have their roots in the ET Pulsar, and culminate in a 'twin' application on the 300ZX twin-turbo VG30DETT. In single form, they are not recommended for performance applications.
Car of Origin: Nissan S13 Silvia/180SX
Engine: CA18DET
Flange: Four-bolt; it fits most Nissan four-cylinder turbo engines
Max. Power Rating: Approximately 130kW
Max. Boost: 1.0bar (14.5psi)
Cover Size: Exhaust 0.48 AR, compressor 0.49 AR
Comments: A small and reasonably ineffiecient turbocharger that should only really be used as a straight fit for an existing CA18DET engine to replace a failed unit. It's not recommended as a bolt-on for a normally aspirated engine of more than 1600cc.
Cost: Normally quite expensive, $450+ due to the replacement demand in the normal service industry for these turbocharger
Rating: One out of five.
Car of Origin: Nissan PS13 Silvia/180SX
Engine: SR20DET
Flange: Same as above
Max. Power Rating: Approximately 160kW
Max. Boost: 1.2bar (17.4psi)
Cover Size: Exhaust 0.64 AR, compressor 0.60 AR
Comments: Improved flowing version of the CA18DET turbo makes it a great straight-fit bolt-on to the CA series, but becomes borderline on even a lightly modified SR20 engine. That the S14 series of cars moved to using a bigger T28-style unit is testimony to this.
Cost: Again, being a straight fit for all of the 2-litre turbo imports makes them an in-demand unit and pushes their cost through the roof. $550+ makes them expensive, but they are a great fit-up for a lightly tuned S13 CA18DET
Rating: Two out of five.
GARRETT T28
The next size up from the T25, the T28 series of turbochargers are more serious items. They are used in twin form on the Nissan Skyline GT-R and singularly on the Pulsar GTi-R, S14 and S15 series Silva/200SX. They make a decent upgrade for the S13 series of cars when more than 150kW are reliably expected to be produced.
Car of Origin: Nissan S14 200SX pre-1996
Engine: SR20DET
Flange: Four-bolt, same as the T25 series.
Max. Power Rating: Approximately 170kW
Comments: The ultimate OE bolt-up to the S13 series of cars, the best part is that it bolts straight on. A good little all-round mid-range turbocharger that has proven itself to be extremely reliable in service.
Cost: Expensive due to their fitment to an Australian-delivered car. Their price starts at $650 for a second-hand unit.
Rating: Three out of five
JDM Vehicles only, not relevean to the UK S14a
Car of Origin: Nissan S14 200SX post-1996, S15
Engine: SR20DET
Flange: Four-bolt, the same as the T25 series
Max. Power Rating: Approximately 170kW or slightly more
Comments: While the housing are the same as the earlier S14 turbocharger, the latter item has sophisticated Garrett ball-bearing internals, which guarantee a faster ramp-up to boost than the previous model. This is the pick of the T28 series.
Cost: They're hard to find second hand due to the relative scarcity of the S14 black rocker cover engines. Normally, you are best off to buy these new from a turbo supplier.
Rating: Four out of five
Car of Origin: Nissan Skyline R32, R33 GT-R
Engine: RB26DETT
Max. Power Rating: Approximately 150kW
Max. Boost: 1.3bar (18.8psi)
Cover Size: Exhaust 0.48 AR, compressor 0.60 AR
Comments: They are really only good for use on stock GT-R engines due to their relatively small exhaust housing. For some reason, they seem to be able to handle more boost before turbine failure, but there are still plenty that have let go.
Cost: Anything with a GT-R part number is expensive!
GARRETT RB20/25 SERIES
Even though many tuners refer to the RB20 and VG30 (single) turbochargers as being a T3, this is not the case. Being a Nissan-branded item and having only Nissan identification markings on them (no AR markings etc.) can make identification difficult. All of the ball-bearing turbos have a telltale 'fatter' centre core section, as well as a bolt through the centre housing, which looks as though it has an effect on the thrust bearing pre-load. Overall, these turbos are very good performers.
Car of Origin: Nissan Skyline R31 GTS
Engine: RB20DET NICS (ribbed rocker cover)
Flange: Four bolt T3 style
Max. Power Rating: 140kW
Cover Size: AR not identified
Comments: A poor-performing turbocharger that was only used on a handful of engines by Nisan before being replaced with the newer technology ball-bearing units. Top-end power is far from good, and the actual response (boost-response time) is also quite poor. It's one to steer away from.
Cost: Dirt-cheap, as they are not in any demand. They have been seen to be as low as $100.
Car of Origin: Nissan Skyline R32 GTS-t
Engine: RB20DET ECCS (silver rocker cover)
Max. Power Rating: 160kW
Comments: A big step in the right direction from both Nissan and Garrett. A truely nice turbocharger, complete with modern aerodynamics and ball bearing construction. It's a perfect choice to get the best from an internally stock, standard injector/management set-up. On a CA18 with a custom manifold, they are really good things.
Cost: Reasonable, with some examples floating around the importers for as little as $400. You have to be quick thoughm as they tend to sell fairly quickly.
Rating: Four out of five.
Car of Origin: Nissan Skyline R33 GT25-T
Engine: RB25DET
Max. Power Rating: Approximately 185kW
Comments: The big daddy of the range makes the RB25 turbocharger good for almost any mild six-cylinder application. Sparkling boost response in the low-rpm range and a reasonably hard-hitting top end make this the most common upgrade found on the RB20DET. It's highly recommended.
Cost: Being very difficult to get hold of makes them highly variable in price. Sometimes about $700, sometimes more.
Rating: Five out of five.
Car of Origin: Nissan Gloria, 300ZX
Engine: VG30DET
Flange: Four-bolt T3 style
Max. Power Rating: 190kW
Comments: Apparently, these are slightly larger in exhaust housing size than the RB25, but have a fractionally smaller and different trim compressor. Information on these is sketchy, but due to their almost unknown application they are easier to find than the RB25 roller. A good choice, particularly if you put the RB25 compressor and cover straight on. In excess of 200kW have been produced with this combination.
Cost: Fractionally cheaper than the RB25 turbo and not as hard to get. They have been advertised at $650.
Fat girls are like scooters...they are fun until your friends see you riding one.
"Did you ever think that it could be that the purpose of your life is only to serve as a warning to others?"
A -> B
Burmonster is offline   Reply With Quote
Old 03-12-2004, 06:19 PM   #3
Blues13
Blues13 is an unknown quantity at this point
OOo... nice info! thanks.
Blues13 is offline   Reply With Quote
Old 03-12-2004, 07:10 PM   #4
jtt220
wow! thank-you..Do you have info on the turbos that power the us spec 300zx twin turbos?
Old 03-12-2004, 10:43 PM   #5
Burmonster
Burmonster's Avatar
The us spec 300zx was powered by dual T-25s.
GARRETT T25
A -> B
Old 03-13-2004, 08:03 AM   #6
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
GARRETT T25
USDM Z32TT = T22 x2
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 03-13-2004, 12:21 AM   #7
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
wow..i jus learned i have a GTR turbo not a S14 turbo...is that good??
..i gotta little boost creep...hhmm and i may have a GTR extension..maybe this is the cause of my creep?? could it be??
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 03-13-2004, 08:52 AM   #8
BSeay
BSeay's Avatar
BSeay is an unknown quantity at this point
Send a message via AIM to BSeay
sticky? i think it would be VERY helpful in this situation....
1995 240SX SE - Sold
BSeay is offline   Reply With Quote
Old 11-26-2005, 11:42 AM   #9
mr_240sx
mr_240sx's Avatar
hey guys, i searched and found this thread.... one of my buddy is selling an rb20det t28 turbo off of an r32 gts-t. I know the flange is a 3 bolt and my exhaust manifold off of my redtop s13 sr is a 4 bolt, i was planning on getting a new exhaust manifold to fit this t3 flange. Is that the only thing i will need to make this turbo fit on my sr? or is there gonna be fitting issues if i try to install it on my sr? and also is it worth it to upgrade to that t28 turbo? because i compared my s13 t25 turbo and that rb20det t28 and they seem as they make the same max power? I thought the t28 was a much better turbo though? so im kinda confused.... can anyone lead me in the right direction and maybe give me advice on if i should pick this turbo up or not.
tks guys,
Mats
mr_240sx is offline   Reply With Quote
