Old 10-16-2012, 12:43 PM   #1
HellaSexyS13
HellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-known
SR engine sputters on cold start. help.
hey guys, so i have a s14 sr20det in my s13 and it started to sputter now when its cold or hasnt been started in a day or two. it has the tomei poncams im not sure if these do it, but it didnt do that over the summer.
i turn the key and it turns over and sputters almost sounds like its going to stall, a couple times it did just shut off again but then it just revs up to its cold idle around 2 grand and once it warms up all the way it drives great, pulls hard and doesnt seem to have a problem at all.
any ideas why it would start like this?
HellaSexyS13 is offline   Reply With Quote
Old 10-16-2012, 05:16 PM   #2
s13havoc
s13havoc is an unknown quantity at this point
same issue
hey, having the same issue with my redtop. also seems to take a lot longer get it to crank when its colder out. would love to know the answer also.
s13havoc is offline   Reply With Quote
Old 10-16-2012, 07:20 PM   #3
The Dude
The Dude's Avatar
The Dude is an unknown quantity at this point
Do the easy stuff first. Clean MAF, IACV, replace PCV valve.
You could possibly have a vacuum leak so check all your vacuum hoses. Good luck.
The Dude is offline   Reply With Quote
Old 10-16-2012, 09:25 PM   #4
sterlinge
sterlinge's Avatar
sterlinge is an unknown quantity at this point
Try some new plugs..
sterlinge is offline   Reply With Quote
Old 10-17-2012, 12:48 PM   #5
HellaSexyS13
everything is new on mine tho, its only been on the road a couple months now and once it starts it runs perfectly fine so most of those things would cause it to sputter constantly correct?
Old 10-18-2012, 04:55 PM   #6
s13havoc
would the throttle position sensor have any effect on that? it looks like someone broke off half the screw that keeps my throttle cable positioned. if they adjusted the idle with the tps, would it cause this? also is there a standard position for the tps, some way to get it back where it "belongs"?
cold start, engine, sr20
