Old 12-16-2012, 02:15 PM   #1
240 GTR
240 GTR is an unknown quantity at this point
Redtop SR20DET Swap
Selling the redtop sr20 setup from my pro-am car. I bought it from JDM-online.com back in 06 or 07. It was used for multiple events up until the end of 2010. It's been a really solid motor...never had any issues with it. I used to run it with an s15 t28 on 16 psi, power fc, sti injectors, and z32 maf. Oil was changed religiously after every event with 10w-40 Rotella T, filters changed every other event. I've had really good luck with this motor, but it's time to move on. Hopefully somebody else can put it to good use.
What you're getting:
-Redtop s13 SR20 Longblock
-s13 SR trans with B&M shifter (no grinds or blown gears. shifts really well, had MT-90 in it.)
-Exedy Stage 2 Clutch (about 14 events on it. still grabs hard)
-Exedy lightweight flywheel
-Engine harness, trans harness, and ignitor (setup to go into SOHC ka s13. has also been modified for a power fc d-jetro, but all maf wiring is still in tact. ignitor gets relocated inside of the car).
-New starter
-Koyo Radiator with Altima dual electric fans and auto fan controller
-Nismo 65C thermostat
-6AN PS Lines, cooler, reservoir
What it needs:
-Turbo, manifold, lines (I have a good t25, gt28rs, hy35, stock manifolds, and lines available for extra.)
-ECU
-MAF
-Injectors
-Alternator needs rebuild soon
-IC and intake setup
-Front and rear main seals leak a little
Price: $2000
240 GTR is offline   Reply With Quote
