Old 01-10-2013, 02:18 PM   #1
donjoel
donjoel is an unknown quantity at this point
sr20det lower harness no power.
The lower harness is brand new from wiring specialties,
Like the title says I'm not getting any voltage to any of
the switches in the transmission, the dash lights work
fine, but not my RPM and MPH gauges nor my reverse light, I put a wire from the starter to my key ignition wire, so at least I'm able to start the engine.
I need ideas and if possible an answer!
donjoel is offline   Reply With Quote
Old 01-10-2013, 02:35 PM   #2
b4l
b4l's Avatar
b4l is an unknown quantity at this point
i had to redo mine like 3 months ago how do you have your grounds hooked up and were is the positive hooked up. i had to redo mine like 5 times before i got it right
you can also email them here [email protected] they are very helpful
b4l is offline   Reply With Quote
Old 01-10-2013, 02:45 PM   #3
donjoel
I did it like the instructions said when I bought the harness, one ground on the alternator casing and the other I just attached it to a plate on the negative battery cable and the positive hooked directly to the battery, I forgot to mention its an s13 engine and chassis, and the motor harness works fine.
Old 01-11-2013, 01:36 PM   #4
b4l
b4l's Avatar
did it turn on when you did not have to rig it
Old 01-11-2013, 01:59 PM   #5
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Why not just use the KA lower harness?
lower harness, sr20det
