Old 02-13-2013, 06:42 PM   #1
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Hoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really nice
Feedback Score: 25 reviews
HKS Wastegate Actuator: Let's Set The Record Straight
As popular as this actuator is, the only information I can find is vague as hell. They always say "adjust until it's where you want it". I've been getting mixed messages that making the rod longer will increase boost while shortening decreases boost, and vice versa. Which is it?
I also need help. I just bought one of these, used. I get it and immediately notice that the bracket mounting holes don't match. I cross referenced the number it comes up as the t25/t28 kit, and the pictures on FRSport match. Instead of drilling the holes out, I decided to undo the spot welds on the stock actuator and use that bracket since it will match perfectly. Not a problem. Get it on and notice that even on it's longest level I have to pull it pretty tight to reach the flapper.
Everywhere I'm reading says it should be able to get long enough to reach and only slightly hold the flapper shut. I went for a test drive and it shot to 17psi(idk if it would have climbed further, I let off). I drive it home and try to see if it will loosen any further. It will but will only have 2-3 threads holding. I got out my air compressor and with it threaded out to this unsafe level it barely opens the flap. Any tighter and it won't open it at all. Did I get a shit actuator? Any help would be great.
Hoffman5982 is offline   Reply With Quote
Old 02-13-2013, 06:54 PM   #2
s13 drifta
s13 drifta's Avatar
Trader Rating: (105)
s13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enough
Feedback Score: 105 reviews
Shortening the rod will increase boost because it puts more tension on the actuator, and lengthening the rod will decrease boost.
PM me for s13 or s14 parts!
s13 drifta is offline   Reply With Quote
Old 02-13-2013, 06:54 PM   #3
KendallH
KendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choices
I believe shortening the rod would increase your boost, as it would be preloading the spring. Are you on a genuine OEM T28? I know the OEM T25 and OEM T28 actuators are different and won't swap over.
KendallH is offline   Reply With Quote
Old 02-13-2013, 07:01 PM   #4
Hoffman5982
Trader Rating: (25)
Are you asking if my turbo is a genuine T28 or if the actuator is a t28? The turbo is the stock turbo on my notchtop. Unless someone upgraded the turbo on an automatic motor in Japan, I'm positive it's genuine. As I said with the kit, when I search the number on the side it comes up as the t25/t28 actuator. I see that the s13 kit is the RN004 and the s14 is the RN005. I'm not seeing either of these numbers on the actuator. Where would they be located?
Old 02-15-2013, 12:10 PM   #5
ghoti
ghoti's Avatar
ghoti is an unknown quantity at this point
IIRC this actuator is compatible with both OEM T25 & T28 as long as you switch over to the correct bracket.
Originally Posted by SaNTi View Post
^ That shit always scares me... and I clinch my asshole a little bit.
ghoti is offline   Reply With Quote
Old 02-17-2013, 12:31 AM   #6
Hoffman5982
Trader Rating: (25)
If that's true then the only thing I can figure is that this one is for a completely different application. I have to use a compressor to push the rod out to get it on the flapper. Even then it opens it maybe a mm or two and that's it. I'm just going to order a brand new one once paypal refunds my money from this jackass.
Old 02-17-2013, 12:45 AM   #7
ultimateirving
ultimateirving's Avatar
One bracket might be thicker or shaped slightly different so the actuator reaches differently. I had a t28 with a hks actuator and used the hks bracket. Also the longer the rod the softer the boost. Stock on the hks should be 11-12 psi I believe.
Z32 with lq4 swap
Old 04-22-2013, 03:36 PM   #8
wutangben
wutangben is making a name for him/her selfwutangben is making a name for him/her self
Send a message via AIM to wutangben
this is an old thread, but for what it's worth to you:
my hks actuator for a t25 requred some "widening" of the holes on the bracket to get it to actually line up for my turbo. not a big deal.
also, it does take some muscle once you've made the arm shorter to reach the flapper. it's been a while since i had/used one, but i remember i'd try to get the flapper to sit as far towards the front of the car as possible, then i'd muscle the rod on.
the original one you bought was probably fine.
it's not rocket science.
wutangben is offline   Reply With Quote
Old 05-06-2013, 11:40 PM   #9
Hoffman5982
Trader Rating: (25)
No, it definitely wasn't fine. At the longest I could get it, past the point of having enough threaded on to be deemed safe, it would not extend any further, making the turbo boost until it eats itself alive. It'd a simple item to install, I'm not that dumb but thanks for suggesting that I am.
I used an air compressor to fully extend the arm, which was still almost a mm too short to get to the flapper. The one he sold me was nowhere near the right one for my turbo, and I took care of that through paypal. Thanks for your condescending suggestion though.
Old 05-06-2013, 11:45 PM   #10
wutangben
glad I could help. thanks for "setting the record straight."
Old 05-07-2013, 10:54 PM   #11
Hoffman5982
Trader Rating: (25)
You didn't help at all, you came in claiming that mine was probably right when I know for a fact it wasn't. Thanks for bullshitting.
Old 05-08-2013, 07:49 AM   #12
songgsan
songgsan is an unknown quantity at this point
songgsan is offline   Reply With Quote
