![]() ![]() Anywho, I've noticed that there is a some power lacking on the top end, some loose nuts and bolts here and there. The general problems as you can imagine. What concerns (sensors, wiring, ECU parameters) should I be concerned with? I've already noticed that the '93 Coupe has a 3 pin MAF jammed into a 4 pin harness (definately a different MAF than in my all stock '91). I'm fairly sure that the '93 has the original ECU and wiring. ![]() ![]() |
Junkie
![]() Join Date: May 2002
Is the check engine light on? Do a search on how to check for ecu codes if so. You might also want to get a 95 mafs because it seems they might have used the 95 harness and ecu.
-Juan |
#3 | |
I'm just wondering if anyone knew off the top of their head if for example X pressure sensor reads 0 - 5 v for '91 - '93 cars and reads 0 - 3 v for '95 and newer. Just the ![]() ![]() |
TTT
I swithced the MAF to the '91 MAF. Idle is better and doesn't stall any more. However the power falls off after 4000+ rpm. It seems to be stronger when engine is cold. Any other thoughts. Timing is set @ 22*. |
