![]() Join Date: Mar 2011
![]() Feedback Score: 7 reviews
J2 Coilover Review
So J2 engineering is a fairly new company, not much info on them. They are identical with the new line that isis and godspeed have been doing but cheaper in price. So i thought I'd do a review on their coilovers for the s13.
basic info Detailed Specifications Front Spring Rate: 8 kg/mm Rear Spring Rate: 6 kg/mm High quality CNC machined steel and aluminum construction 46mm Mono-tube shock design Independent ride height adjustable Perch, doesn't compromise Preload (Spring Rates) 32 Way dampening adjustment for rebound Front camber plates are Included Fully assembled applicable on certain applications only 100% Brand New, Never Been Used or Installed Professional installation is highly recommended ANYWAYS on to the Review pick them up for a great deal. Just hit up Jonathon, [email protected], he'll hook it up FAT ![]() So the box was well packaged, came with extra hardware, studs(which was nice), wrenches. blah blah blah ![]() ![]() ![]() The install went well everything fit like a glove, I had no trouble. ![]() Camber adjustments. basic ![]() How my car sits. I also took the car for a test drive ![]() ![]() wheel specs are 18x10-18 18x12.5 -32 ![]() ![]() PROS I had 1. The rear mounts are fully threaded so they bottom out. (to go lower) 2. About 4" drop from stock height. 3. Great deal for coilovers under 700 4. Ride quality was great, perfect for daily driving, could stiffen it up for track as well.( I've ridden in tein, stance, d2,emusa) I say the comfort is very close to stance and tein, mess with the dampeners a bit and they possibly just as good. 5. The shocks have wider and larger threads so it doesn't take a thousand years to lower and raise the shock mount.I mean sitting there for a minute unwinding those things is ridiculous, but not with these 6. Dampening capabilities/pillow ball mounts. A lot of the cheaper coilovers don't offer this. 7. They don't need to be broken in. Such as megan, ready to install and go. CONS I had 1. The collars that hold the spring perch weren't tight. Maybe it was just my set, but no biggie. just double check and tighten if you pick up a set. 2. They provide new nuts for the studs on the camber plates/ mounting plate. So you're gonna need a 13mm and 15mm instead of 12mm and 14mm they bumped it up another mm. Idk why 3. I stiffened up the dampener to 32 clicks up front and 30 in the back it was pretty bad, horrible actually. fking bouncing all over the place. Clicks are counting up from most soft to hard. avoid using the higher settings Well no much to complain about YET, but ill keep this updated and answer any other questions. These coilovers have potential, I'll see how long they'll last, but i highly doubt they will blow anytime soon. Last edited by Laotian240; 03-15-2013 at 04:19 PM.. |
#2 | |
![]() Join Date: May 2009
Who are they made by? They look like they could come out of the BC factory.
Need to adjust your idle? http://zilvia.net/f/s-chassis/395413...-pictures.html |
#4 | |
Thanks!
Taiwan Bor-Chuann= BC-racing = |
#5 | ||
#6 | |
![]() Join Date: Dec 2007
Trader Rating: (63)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 63 reviews
So it's same shitty garbage coilovers then? Their new line? LOL. I am curious about your previous experience with other coilovers. |
![]() Join Date: Nov 2006
And so we add another one to the list of hundreds of generic coilover brands. Another to the list of coilovers that "ride good".
This is an incredibly well done review, I can't complain, you were doing great up until it said "the dampeners are well valved". No they aren't. They're Taiwanese cheap coils just like the last new brand of coils. Let me repeat, I think you did a great job on your review, I'm just making the point that it appears these are just another brand of generic coilovers, just like all the others. |
Thanks! Yeah I see were you're getting at. Past few years coilovers brands keep popping up. I think this batch of coilovers is different though. Industry is growing so its easier and cheaper to develope quality products. But I have no way to prove it yet. Just an opinion. But thanks again for looking over my review
#12 | |
thanks ill be going 18x11 up front soon. |
#13 | |
How are the sharp fast bumps? Catch any air on them?
#15 |
![]() Join Date: Sep 2012
I'm sorry, but a product review after having them for two measly days? The fuck man. Spend some time with them, get to know them, then right a review. Fuck, it takes me more than two days to get a good idea of how it is to jerk it with the leftie rather than right.
#16 | |
![]() Join Date: Oct 2011
What about alignment settings? What did you change before? What are your new specs? You have any lap times to compare them to? Did you corner-weight and balance the set up? What about your sway bars? You have to adjust those to balance over-understeer? What's it feel like mid corner? Does it push on corner exit? What about your previous suspension mods? Any changes to those? You adjust castor to improve turn-in? I like how you drop your ratty-ass car to the ground, never even mention getting it aligned and automatically state "the handling is improved". The fuck? And what's your definition of "ride's good"? Is it driving while keeping your teeth from chattering? Does a pot hole unbalance the entire car? What about the low-speed damping? High-speed? What the fuck difference does a click make? How many clicks does it take to make a difference? Does the nose dive under hard braking? What about squat on acceleration? These are just some of the questions I'd expect from an actual coilover review and this isn't a fucking review, it's a circle jerk of self-congrats for buying a shitty set of coilovers meant for nothing more than bandwagon jumping.
May the bridges I burn light the way. |
#17 | ||||
About the short fast bumps idk if i've gone over any yet, but it feels like they're absorbing most of the impact. i don't feel any jumps, or spikes.
1-8: Suggested for track use. 9-16: Suggested for mountain/aggressive use 17-32: Suggested for common street use. And as for a review, it is an opinion that is what a review is, my opinion. And theres no bandwagon, i don't see how there could be a bandwagon here, I'm not here to convince you to buy these nor sell them to you. This is answer any questions and give more insight for people who consider to buy these. if your're not interested fuck off and find a bandwagon to jump onto. Quote:
As for being a new line, i said maybe. Since BC racing is the manufacturer, it is possible they engineered a new line. And other coils i've experience is emusa, on my own car, which i got off a trade. And my friend had d2 and stance currently. |
#18 | ||
#19 | |
#20 | |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
As mentioned by the OP, this review will be updated periodically so the "review" does not stop at the first post. Anyway, carry on. |
#23 | |
Take a look at the picture below. ![]() A critically damped scenario is what you want. Overdamped (too stiff) = harsh ride and underdamped (too soft) = bouncy ride. |
#24 | |
#25 |
No one get pardon here mayne lol.....nice review op keep us updated as promised
***FortuneMinds*** 95 240SX S14 / 14 Lexus IS250/ IG / Twitter: juvi22003 |
#27 |
Oh man sorry to hear.....
