![]() So i picked up a s14 that had already had the rb25det swapped in but it runs like poop so i was hoping you guys could possibly give me some insight on what could be the problem.
It idles right around 14.7 when I hit the gas the air/fuel guage gets over 17/1 and then drops down to around 10/1 a few secounds after and runs super shitty. Ive checked all the vacuum lines and change almost every hose just to make sure, cleaned the maf and changed plugs and checked the coil packs. Any one have any suggestions on what this could be? how to fix it? mods are aem uego wideband aem tru boost controller freddy intake manifold with a big throttle body large fmic walboro pump |
i was fiddling around with it and noticed at 2000rpms its drops down to 1500 and if i hold it at 2000 its bounces between 1500 and 2000 repeatedly any ideas? coolant temp sensor?
heres a video showing that problem^
Rb25 revving problem - YouTube |
Man w/ CTSV & a Car Seat
I'd say TPS...but since you said you just picked up the car and it runs like poopie, I'd go over the whole engine just to get the warm fuzzy. I'd double check the mechanical timing on it and make sure the timing belt marks all line up at TDC. Re-stab the CAS, reshoot it and make sure the base timing is at the 4th mark from the left (0, 5, 10, 15). Double check the spark plugs, should be atleast a heat range 6 and gapped to .030. Wouldnt hurt to spray the MAF sensor filament with a MAF sensor cleaner.
#15 |
You can atleast put it on TDC, take the cam gear cover off real quick and atleast verify that the belt timing marks line up on the gear marks. If they're off, turn the crank over a couple of times and see if it would line up. If they're off still after a couple spins, then you'd have to pop the main pulley off and get the front cover off.
