![]() Join Date: Aug 2008
S20det redtop maybe issue? Need some help
ok my Sr20det is working fine...
but just started having fuel smell when i start up or come to a stop at lights and i can smell some in oil as well.. i got new stuff on motor like O2 sensor Water temp new spark plugs new knock sensor new used maf Car still make power no problem Part2 question at 75% throttle my car will over boost to 20psi if i stay in that gear till redline now if i do 100% throttle car will only boost to 10psi and even under 70% it will only boost to 10psi as well
Ripping up the Highway since 03 |
![]() Join Date: Jun 2007
With no boost controling mechanism, the turbo is going to boost at whatever pressure happens to be enough to push the wastegate open at the time... given whatever conditions are at hand.
If you have an adjustable actuator, loosen it up. Other than that, it sounds like the car is operating as it should. As far as fuel in your oil; oil smells different after being ran thru the car... If you aren't losing oil or noticing any smoking, loss of power etc, then chances are everything is good.
New 300zx filter new fuel line. And new hoses on tank all and no vac leaks check and I can't find any leaks how hard is it to change injector seals and u think maybe that could be it?
do you see any excess fuel on the intake manifold ?
that would be a good sign of a shot o-ring on the injectors.
Two-Tone owner#011509-Lightly Modded ![]() |
