Old 07-18-2013, 04:29 PM   #1
Abc916
Abc916's Avatar
Abc916 is an unknown quantity at this point
Helpp! Differential swap issue, 300zx diff makes grinding noise
So I had a non turbo 300zx diff and swapped out the open. Put everything back and filled it with 2 qtz of gear oil. Drives fine but makes a loud grinding noise after moving into second gear. Any tips or advice? Might just weld the old one and put it back in
Abc916 is offline   Reply With Quote
Old 07-18-2013, 04:30 PM   #2
Abc916
Abc916's Avatar
*i drive a s13 hatch, ka
Old 07-18-2013, 05:21 PM   #3
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
sounds like somethings wrong with the diff. take it off and open it up and inspect. what more can you do?
rebornS14 is offline   Reply With Quote
Old 07-18-2013, 06:46 PM   #4
Abc916
Abc916's Avatar
Yeah that's what my buddy had told me when we drove it down the street. Could it be that I put too much oil or not enough? if the diff is bad im thinking of putting the open back on welded.
Old 07-18-2013, 10:03 PM   #5
Paint209
Paint209 is an unknown quantity at this point
When i swapped my open out for a vlsd, it made noise for a while. But then it just disappears after a while.
Paint209 is offline   Reply With Quote
Old 07-18-2013, 10:09 PM   #6
Lilredsx
Lilredsx is an unknown quantity at this point
I just swapped mine out also for a lsd and it makes grinding noises when I turn left or it the car is loaded. Are lsd rear ends supposed to make noises?
Lilredsx is offline   Reply With Quote
Old 07-19-2013, 12:40 AM   #7
Abc916
Abc916's Avatar
Hmmm. I can drive the car fine and actually feel a difference. Just that grinding noise. I put everything back together the way it was. Ill drive it one more time before I get under there and pull it out again. unfortunately don't have a garage. Paint209 how long did the noise last??
Old 07-19-2013, 12:45 AM   #8
Paint209
I'm not sure, but it wasn't that long. probably a couple weeks.
