Old 07-22-2013, 06:48 PM   #1
jruiz801
jruiz801's Avatar
jruiz801 is an unknown quantity at this point
s14 S14 getting hot help me plz
I just got my s14 and it keeps getting really warm and the coolant temp spikes so I decided to change the thermostat and I open it and it doesn't have one if its not my thermostat then what else can it be help plz
240sx S14 Kouki work in progress
jruiz801 is offline   Reply With Quote
Old 07-23-2013, 01:42 AM   #2
jruiz801
jruiz801's Avatar
changed thermostat and water pump and its still overheating
Old 07-23-2013, 07:47 AM   #3
s13 power
s13 power's Avatar
s13 power is an unknown quantity at this point
Did you flush air out of your coolant system? check your coolant temp sensor to
s13 power is offline   Reply With Quote
Old 07-23-2013, 07:53 AM   #4
Mikester
Mikester's Avatar
Dude- How's life in Clovis? I'm from Hanford
If you put in a new water pump & thermostat, the very first thing you need to do is see if it's leaking or boiling out the overflow reservoir. If you are losing coolant, then there's your problem. If not, and you have the OEM clutch fan AND SHROUD, then drain out all of your coolant & flush the system; then re-service the entire system with distilled water and Water Wetter.
ka24de, overheating, s14, thermostat
