Code 34 s13 ka24de
The car is a 1992 240sx with a used motor that was put in about 6 months ago. It has never ran quite right and I am trying to get it running correctly. There had no check engine light on so I didn't think to pull the codes until now.
It came up with code 34 and that is it. I was wondering if it could be a false positive, my car has solid poly urethane motor mounts? Will this put the car into limp mode? Currently the motor starts up easily and cruises well with no smoke. However when I am accelerating sometimes it will bog a little or lag and then catch and start accelerating. The car has no AIV, charcoal canister or cat. Cone filter and crappy 2 inch catback (the old one broke off lol). New: Spark plugs gapped properly, plug wires, distributer cap and rotor, fuel filter, air filter, new oil filter and 10w30. It does make a ticking sound once with each motor revolution but I think that is lifter tick but I am not sure. I am getting a compression tester today and I will post the results. How would I tell if what the ticking sound is and please help me fix this bogging it is driving me nuts. |
Also the bogging only happens right around 2700 rpms and will only do it for a split second most of the time or not at all and only at about a quarter throttle (Wot it will not do it) but sometimes it is more noticeable seemingly at night when it's cooler outside. I just went outside to make a video of the car but the ticking was inaudible and it only bogged once for about a half a second and you really couldn't notice it on the video.
I read all of the stickys and at first I thought it might be IACV but my idle is fine it idles at 1100 when cold and then settles down to normal very quickly.Please excuse the trunk rattle, this is the car on startup. No ticking is audible just trunk rattle.
And acceleration no lag at all today. |
Code 34 is the knock sensor, which causes the timing to be retarded for safety, which may be causing the bog issue. Check the knock sensor wiring and replace the knock sensor if necessary.
NismotronicSA - Speed-Density Tuning for Nissans |
Had the same code thrown along with a maf error code. Took weeks to figure out. Ended up being a short in my fuel pump wiring inside the gas tank that was throwing all the codes. Also had bogging issues. I would check all your harneses.
If you do replace the knock sensor it is also a good idea to do the harness sensor at the same time. |
#9 | |
![]() Join Date: Sep 2004
If your engine is going to knock, it's gonna knock. That sensor isn't going to do shit to save it. |
I forgot to mention that I already knew that code 34 = knock sensor. Harness is beyond shit from the previous owner, I didn't notice it at first but the more work I do on the car the more splices and electrical tape I find
![]() Found this as well. "Solid motor mounts/worn broken motor mounts will/can make a solid connection to your chassis causing extreame vibrations at idle and low rpms. Normally the stock mounts dampen this. Our knock sensors should pick up on these vibrations and retard timing. This will make your car "slower than it was." |
