Old 09-26-2013, 08:53 AM   #1
crazedcola
crazedcola is an unknown quantity at this point
tag lights noy working
I have a 1995 s14 240sx. My tag lights won't work. Checked fuses under kick panel and the one for tail lamps is blown n I switched it witg my room lamp fuse and they still don't work
Any suggestions
crazedcola is offline   Reply With Quote
Old 09-26-2013, 08:56 AM   #2
Alamo_City_210
Alamo_City_210's Avatar
Alamo_City_210 is an unknown quantity at this point
did you check the bulbs themselves?
Alamo_City_210 is offline   Reply With Quote
Old 09-26-2013, 09:37 AM   #3
crazedcola
Yes. I replaced them before I looked at anything else
Old 09-26-2013, 10:51 AM   #4
cotbu
cotbu's Avatar
The fuse could have blown, soon as you put it in. Did you put it back in the room lamp spot?
here's what you do if you did, put in another fuse, check the voltage on both sides of the fuse, then at the light socket. If there's power there with the lights switched on, the lights should work. If the fuse blows you have a short. check the voltage at the socket with the lights off. finding the short, if there's one should be fairly easy.
Are your running lights working? or is it just the tag lamps not working? Do the brake lights work?
Old 09-26-2013, 10:54 AM   #5
crazedcola
Yes all other lights work. Ill go ahead n check voltage when I have a chance. I'm work right now. Ill post results after ty for input
Old 09-26-2013, 04:29 PM   #6
crazedcola
Well I bought new fuses and got electronic parts cleaner n cleaned the connecters. So they are workin now. Don't know what did it but its good now. Ty again for all the input
Old 09-30-2013, 12:52 PM   #7
josh350gt
josh350gt is an unknown quantity at this point
Thumbs up
if all else fails run a new line and an inline 10amp fuse and connect it to the taillight/driving light. MAKE SURE its the driving light not the brake otherwise it would just come on when you hit the brake.
josh350gt is offline   Reply With Quote
