Old 10-30-2013, 10:34 PM   #1
rockqian
rockqian is an unknown quantity at this point
Exclamation Lights won't go off! Need help
Hey everyone, I have a 98 240sx with sr20det, I got a HID headlights for it long times ago and it was always working fine. But tonight, I found out that the lights won't go off, even I turn of the ignition and pull out the key. the tail lights and DRL stay on, actually are flashing, I can hear the relay was clicking...when I open the door I can hear the warning sounds to remind me pull out the key or turn off the light whatever...I tried to disconnect the battery, but as soon as I connect the battery it goes on again....anyone have idea about this situation? Thanks!
rockqian is offline   Reply With Quote
Old 10-30-2013, 11:19 PM   #2
!Zar!
!Zar!'s Avatar
You could try unplugging your headlight stalk to see if that turns everything off.
Sometimes those go bad.
Though I've normally only seen them go bad on s13's.
Old 10-31-2013, 05:44 PM   #3
rockqian
is there anyway to check the stalk before I replace it? I tired the car this morning, the lights now stop flashing and just stay on...
Old 10-31-2013, 05:59 PM   #4
tougefactory
tougefactory's Avatar
tougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to all
Check your driver side fender harness also.
Performance Parts // Track Prep // Fabrication
**Follow us on Instagram @TFWorks
For all the latest TF★ news visit our blog!!
tougefactory is offline   Reply With Quote
Old 10-31-2013, 06:08 PM   #5
rockqian
OMG shit, I think that maybe the problem, the fender is damaged! all the wires exposed and the coats are gone....thank you very much! do you know how much it will cost to fix it?
