![]() Join Date: Oct 2003
![]() I heard that the t25 and the t28 both use the same turbine, so i was wondering what exactly is the difference between the two?
I was thinking of getting a t25/t28 hybird, .48 turbine, .60 compressior. but is that just the same as a t28? I want the closest to Zero lag i can get. |
![]() Join Date: Apr 2002
I was under the impression that not all T28's were ball bearing.....
Also, checkout www.cheapturbos.com for info on the T28
89 S13 hatch/////98 Subaru 2.5RS |
K! Is It Or Is It Not Ball Bearing Make This Clear Now!
S15 T28 Turbo(yes The Stock 1) Is It Ball Bearing!
if it aint broken, fix it(95 240/96 sr20) |
![]() Join Date: Sep 2002
try the archives on Freshalloy or go to the specs page on heavy throttle. the turbo specs are on there.
Keeping it Godzira bishes. So I murdered another turbo |
this info is so easy i'll be nice;
Redtop T25: Compressor: T-25, 60 trim 56mm BCI-1 compressor. Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing. Center Section: Journal bearings S14 Blacktop T28: Compressor: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing. Center Section: Ball Bearing S15 Blacktop T28: Compressor: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing Turbine: Inco turbine wheel. Cast divider wall between turbine discharge and wastegate. Center Section: Ball Bearing
Keeping it Godzira bishes. So I murdered another turbo Last edited by Steeles; 06-01-2004 at 10:03 AM.. |
