Old 12-18-2013, 01:52 PM   #1
salemmotorsports
salemmotorsports is an unknown quantity at this point
s14 Spec Clutch Part #'s
Hello Guys,
I am looking into picking up a new clutch for my s14. I have a s14 sr20det swap in it. I decided to get a spec clutch, possibly a stage 2+, but they have two different stage 2's and I am not sure which one to pick up. I put some links from FRS down below. One part# is "SN333H" and the other is "SN332H-2." Does anyone know the signifigance of the "-2" on the end of the second part number because there is a several hundred dollar difference between the two?
I am not really looking to start a debate on which clutch brand to pick. I am just curious about the difference in these two specific clucthes. Thanks ahead of time for any help. I haven't been able to find anything on it.
http://www.frsport.com/SPEC-Clutch-S...3_p_13707.html
SPEC Clutch SN333H-2 Stage 2+ Kit Nissan SR20DET-S13/S14 1989-2000
salemmotorsports is offline   Reply With Quote
Old 12-18-2013, 09:50 PM   #2
Fuego
Fuego is an unknown quantity at this point
I'd say it's a mistake in the listing unless it comes with a flywheel. $368 is what Spec charges for 2+.
If you want to save a little money, a stage 2 will be more than enough for a stock SR.
Fuego is offline   Reply With Quote
Old 12-24-2013, 04:50 AM   #3
240SilviaX
240SilviaX's Avatar
240SilviaX is an unknown quantity at this point
the -2 after the part number is the 254mm disc upgrade + flywheel . Go to specclutch.com and it has a breakdown for all part # and tq limits. the -2 line holds alot more power
240SilviaX is offline   Reply With Quote
Old 12-24-2013, 04:55 AM   #4
240SilviaX
240SilviaX's Avatar
Here I hope this answers your question
SPEC Clutches & Flywheels: Auto Parts, Domestic, Import, Truck, Racing, Drifting :: Results By Car
the Dash -2 after the part #= 254mm clutch and flywheel upgrade. (factory is 240mm) so you would be getting a f/w
clutch, s14, spec, sr20det
