Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 02-24-2014, 09:28 AM   #1
[email protected]
Luis@sflautosports.com is an unknown quantity at this point
Send a message via AIM to Luis@sflautosports.com
♛♛ Monday SUCKS ~ AEM EMS/AEM Electronics SALE || RB, SR, KA, 1JZ, 2JZ, 13BTT ♛♛
Whats going on fellas?
After the warm welcome the fellow community has given us and the awesome support. We have decided to run a AEM Electronics products promo $ale.
I'll beat anyone's advertised price!
Available for MOST cars, Just ask!
PM me or Email me for more details!
[email protected]
AEM’s Series 2 Programmable Engine Management System is more powerful than its predecessor. In addition to more robust hardware, there are several improvements over the original EMS, noted in the chart below. Like its predecessor, AEM's Series 2 Plug & Play EMS plugs directly into a vehicle's factory ECU harness and requires no additional wiring or hardware. Windows™ compatible software (XP, Vista, Windows7) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. Our new AEMTUNER software is infinitely adjustable software and allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition.
  • Plugs directly into the factory harness. No rewiring necessary.
  • Uses all the factory sensors.
  • Includes start up calibrations.
  • System is fully enabled and unlocked - Never pay for upgrades!
  • Context sensitive help eases tuning process.
  • Maps can be password protected by the tuner to prevent unauthorized usage or sharing.
  • Runs on Windows-compatible software
  • Up to 12 peak and hold injector drivers.
  • Up to 8 direct-fire coil outputs.
  • Up to 16 general-purpose outputs.
  • Up to 8 definable switch inputs.
  • Up to 4 EGT inputs with fuel trim.
  • 1MB of internal data logging.
  • Electronic boost control.
  • Full idle control.
  • Programmable traction control.
  • Software definable knock control.
  • Two step launch control.
  • User configurable soft-cut rev limiters.
  • Wet or dry nitrous control.
  • Tune using new USB communication port or serial port.
  • Works with all AEM gauges.
Digital Gauges
WIDEBAND FAILSAFE GAUGE
Wideband Air/Fuel and Boost in One Gauge!
It actively protects your engine by constantly monitoring AFR curves and activating a user-defined failsafe strategy. It can save an engine from catastrophic damage.
Displays both boost or vacuum and AFR or Lambda simultaneously on the same gauge
Internal boost sensor
Bosch Wideband UEGO sensor and weld-in bung included
On-Board 3+ hour Datalogging capability at 20hz per parameter
Full color Organic Light Emitting Diode (OLED) Display in center, user selectable feature (boost/vacuum or AFR)
Intuitive set up software
No free air calibration required- ever
DIGITAL WIDEBAND AIR / FUEL GAUGE
A wideband air / fuel controller and gauge interface in one unit!
Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
Does not oscillate AFR reading like narrow band sensors
No laptop required for monitoring!
Bosch sensor included
TRU-BOOST GAUGE TYPE CONTROLLER
Combines digital accuracy with manual controller-like ease of use!
No external interface required for programming!
Complete system includes harness, boost hose, on-board 29 psig pressure sensor (external 75 psia optional), boost solenoid, gauge display and all necessary fittings
Quick connect technology eases the installation process
WATER TEMPERATURE DISPLAY GAUGE
A complete gauge system that includes a sensor and requires no additional parts.
Gauge temperature range 100-300F
Includes easy-to-install harness and sensor
Complete stand alone gauge requires no additional sensors or programs to operate
Ideal for both fuel injected and carbureted motors
LED displays provide precise reference to critical operating
TRANSMISSION TEMPERATURE DISPLAY GAUGE
FUEL PRESSURE DISPLAY GAUGE
Gauge pressure range 0-100psi
BOOST DISPLAY GAUGE
Gauge pressure range -30-35psi and -30-50psi
OIL TEMPERATURE DISPLAY GAUGE
Luis@sflautosports.com is offline   Reply With Quote
Old 02-26-2014, 11:36 AM   #2
mikegeo
mikegeo is an unknown quantity at this point
Do u have 1jz gte aem v1
mikegeo is offline   Reply With Quote
Old 02-26-2014, 11:52 AM   #3
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
how much for a rb25 v2??
supersayianjim is offline   Reply With Quote
Old 02-26-2014, 01:13 PM   #4
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Price on AEM 3.5Bar Map sensor and Wideband pllzzzzz to 33305
BiG MiKE86 is offline   Reply With Quote
Old 02-28-2014, 09:52 AM   #5
Luis@LateNightAuto
Luis@LateNightAuto's Avatar
Luis@LateNightAuto is an unknown quantity at this point
We'll beat ANY advertised price!
Just PM me and Find out!
Luis@LateNightAuto is offline   Reply With Quote
Old 03-05-2014, 01:20 PM   #6
[email protected]
Guys if you placed an order Mon-Tues, They were processed today and being shipped out today as well.
Thanks again for everything!
Those of you who havent, dont miss out on this deal!
Old 04-24-2014, 08:20 AM   #7
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
Aem tru boost sent to 94805
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 05-06-2014, 06:34 PM   #8
Lorenzo89
Lorenzo89's Avatar
Lorenzo89 is an unknown quantity at this point
Send a message via AIM to Lorenzo89
price for rb25 AEM EMS2 and tru boost w/ wideband shipped too 91766?
Lorenzo89 is offline   Reply With Quote
