sr20det smokes on decel
ok so my local shop is too busy doing their formula d cars and cant return my calls.. so ill try here.
ok so had a decel smoke problem, many suggested/ forums sugeested valve stem seals so i got bored, ripped the head off last night and replaced valve seals with oem seals. STILL does the exact same thing?!?!?! the turbo is fairly new but has in and out shaft play what would be the easiest way to determine exhaust housing seal and or turbo would be bad? there is very minimal oil in the hot pipe cold pipe.. any help is greatly appreciated!!! sr20det blacktop s13 garret gt28rs turbo triple layer head gasket arp head studs catch can greddy front mount hks exhaust 10 lbs stock ecu and injectors |
![]() Join Date: Sep 2005
there should be no oil in the hot pipe, if you think the turbo is leaking from the cold side, then check for oil in the intake manifold.
if there is? remove the intercooler, piping and manifold, and get to cleaning. the oil could be pooled somewhere and getting blown through the system. Now, valve stem seals wont make the hot pipe have oil in it, but the exhaust manifold, turbo, down pipe etc. will. Here pulling the exhaust mani can tell you, if it's the turbo or engine leaking oil. if there is no oil in the manifold then it's probably the turbo. I would do a warm up, then shut down! let er cool down, hope for the easiest fix.
![]() Join Date: Dec 2004
Trader Rating: (58)
How is your crankcase vent/pcv system set up?
if i stay outta boost it doesnt smoke as bad. so my vent system is hose from crank case (block) to "T" the out to a catch can then from catch can to the MAF adapter. The Pcv side is from the PCV valve out of the valve cover then "T's" into the intake manifold and the other side of the "T" to the brake booster.
thanks for your guys' replies BTW.. im just stumped- ive had it all happen to my oil dip stick blowing out due to the hoses being too short on my catch can. but never a smoke issue on decel. i had my money set on valve seals.. didnt seem to help. i really am leaning towards my turbo at this point. when i did the head gasket and ARP head studs 2,000 miles ago it wasnt doing this. it happened in the last 1,000 miles
thats what im thinkin. dont know about the restrictor. called FRsport who i got the turbo from and they recommended the .04 oil restrictor. running the same turbo on my coupe with 0 issues. ive never ran a factory oil seperator
![]() Join Date: Dec 2009
Ive noticed most times when car smokes on decel its valve guide seals,could purchase a borescope on ebay for like $25 and take a peak,do you have a vacuum guage and does vacuume flutter?
![]() Join Date: Jun 2003
Trader Rating: (130)
most likely turbo seals.
have you checked ANY of the things listed? Like oil in the charge piping, or in the intake, etc. |
