Old 03-23-2014, 12:59 PM   #1
jerryscherry
jerryscherry is an unknown quantity at this point
Clutch Pedal Vibration, Grinding sound?
Clutch pedal vibrates while engaged, also noticed a grinding/vibrating sound.
the vibrations,sound changes with the rpm, as rpm goes up the vibration/sound gets louder.
it seems to get better after a few minutes of driving. i think the vibration/pedal is still there if you go high rpms though like 4000 and up, but not as bad as in the morning.
also noticed pedal is a tiny bit more soft on cold start, but gets more stiff after a few minutes of driving.
just changed new master , slave, and a steel braided clutch line.
any ideas? weird that it gets better after few minutes of driving.
jerryscherry is offline   Reply With Quote
Old 03-23-2014, 02:39 PM   #2
Kingtal0n
Kingtal0n's Avatar
SR ? KA ?
Sounds like you need to pull your transmission and check the throw-out bearing. Expect to replace it while you are in there (order a new one in advance) might as well.
good time to replace the clutch also. And the pivot ball (buy a nismo).
tinyurl.com/4l80er
Old 03-24-2014, 01:02 PM   #3
jerryscherry
Originally Posted by Kingtal0n View Post
SR ? KA ?
now that you mention it,
This is a SR, just recently did a clutch job, with a RPS Streetmax Clutch/pressure plate, resurfaced oem flywheel
when we were doing the job, the pilot bearing was cracked and broke off LOL. but we replaced that with a new one, but we noticed the input shaft/sleeve where the TOB goes on was also cracked, hmm maybe this was the problem? maybe after a while it just completely cracked.
the weird thing is, its worse in the morning, but after driving for a few minutes, the vibration/sound is almost completely gone, unless you are in high rpms.
