Old 05-08-2014, 05:29 PM   #1
cflory08
cflory08's Avatar
cflory08 is an unknown quantity at this point
No dash lights on my s14
I have a 95 s14 and none of my dash lights work... is there a fuse that could be blown? I checked both fuse boxes and there wasnt anything that said what fuse was for the dash..so im not sure what to do next all the gauges work just no lights..
cflory08 is offline   Reply With Quote
Old 05-08-2014, 07:12 PM   #2
marks14
marks14 is an unknown quantity at this point
check the "meter" fuse in the drivers side kick panel
marks14 is offline   Reply With Quote
Old 05-08-2014, 08:53 PM   #3
cflory08
cflory08's Avatar
Checked it.... not blown i replaced it anyway but still no lights... I also changed the bulbs hoping they were bad and still nothing =/
Old 05-10-2014, 01:40 AM   #4
turbos14
turbos14's Avatar
turbos14 is an unknown quantity at this point
Check the FSM wiring diagram for the dash diagram. That will show u what fuses and wire colors and connectors that could be wrong. Use a test light to see if you have power up to the fuse then work your way in deeper to the circuit
Sent from my SGH-I747 using Tapatalk
turbos14 is offline   Reply With Quote
Old 05-10-2014, 12:53 PM   #5
Agamemnon
Agamemnon's Avatar
Its probably your dimmer switch. It supplies voltage to the illumination circuit for the whole dash.
Old 05-10-2014, 07:28 PM   #6
AWD260R
AWD260R's Avatar
AWD260R is an unknown quantity at this point
yup, that's my guess, OP did you remove this switch? if so plug it back in and try again. I took my car out for a test drive and forgot this switch and the hazard button, hazard allows for turn signals. Lucky in OK people don't really use turn signals :P
AWD260R is offline   Reply With Quote
