Old 06-22-2004, 03:12 PM   #1
Natty
Natty is an unknown quantity at this point
Do these TC bushings look bad?
I finally went to look at my TC bushing which I suspect are the culprit of at least some of my wheel shimmy.
Do these look they need to be replaced? They have 170,XXX miles on them and they are cracked, but not yet oozing.
1991 White 240sx Fastback LE, rusty spoiler, weak driveshaft, exhaust rattle....
Rattles are just your cars way of saying 'I love you.'
Natty is offline   Reply With Quote
Old 06-22-2004, 03:20 PM   #2
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
Oh ya, those are toast. What are you going to get to replace? Tension Rods or TC Rod Bushings?
It could be many things that make your wheel shimmy, when was the last time you got an alignment?
West - Zilvia.net - Toyobaru.net - NapkinSketch.com
West is offline   Reply With Quote
Old 06-22-2004, 03:34 PM   #3
Natty
I'm positive these are cuasing the shimmy. I've beat this topic to death, lol.
I have a lifetime alignment, so I get it done every 6k, along with balances and rotations.
Also on the list are outter tie rod ends, wheel bearings (squeak!) and some simplegreen to clean my nasty undercarriage.
I was just wondering how the TC bushings were.
Thanks!
EDIT- Ordering Nismo bushings to be used with my current rods, since ES and Whiteline crack lower control arms, from what I hear.
Old 06-22-2004, 03:44 PM   #4
pruto
pruto's Avatar
pruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to all
why not just get aftermarket tension rods?
Paul
Black and Red
pruto is offline   Reply With Quote
Old 06-22-2004, 03:50 PM   #5
Natty
No money and I want to stay stock.
Old 06-22-2004, 04:15 PM   #6
Natty
Okay, just ordered some Nismo bushings from Courtesy, along with some outter tie rod ends from Napa.
Thanks guys.
Old 06-22-2004, 04:49 PM   #7
West
OMNOMNOMNOM
West's Avatar
I would have got some Tension Rods... but whatever floats your boat. You can find them for $130 Shipped, if that. Probly less then what you paid for your combo.
Old 06-22-2004, 10:31 PM   #8
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
the nismo bushings come with rods.
andrave is offline   Reply With Quote
Old 06-22-2004, 10:57 PM   #9
thx247
thx247 is an unknown quantity at this point
when I was autoxing my 240 I noticed a shimmy under braking, it was fixed by replacing a perfectly good looking TC bushing.
I think you're on the right track, aside from the strut, thats the only other major rubber piece in the front suspension.
thx247 is offline   Reply With Quote
Old 06-22-2004, 11:25 PM   #10
TheTimanator
TheTimanator's Avatar
That's what mine looks like, but I'm gonna upgrade. I had a shimmy when I braked before until I replaced my rotors/pads. Now the steering wheel shakes at 55-60mph with the new(used) wheels. Good excuse to get another set of wheels I suspose....
Old 06-23-2004, 01:26 AM   #11
S14DB
AFC #1
S14DB's Avatar
Where did all the Oil come from? Your pan is coated.
Old 06-23-2004, 10:07 AM   #12
Natty
I knew someone was gonna point that out. I honestly don't know, it was like that when I bought it. I know for sure I am not losing trans or engine oil, so I guess the previous owner had something to do with it. I am way too lazy to clean it though.
The Nismo buhsings probably don't come with rods. I paid like $35 a pop from Courtesy.
The shimmy actually appeared after I removed my rotors and caliper for inspection, but I didn't replace anything. I guess I'll try that one too.
Old 06-23-2004, 11:30 AM   #13
AKADriver
AKADriver's Avatar
I find pillowball rods to be really harsh, and they didn't fix my shimmy in my old car (which turned out to be the steering rack). Stock or nismo are the way to go in a car with stock or near-stock suspension.
Old 06-23-2004, 12:07 PM   #14
jmauld
jmauld is making a name for him/her selfjmauld is making a name for him/her self
Send a message via AIM to jmauld
AKADriver, what was wrong with your steering rack to cause a shimmy?
Not less then the 2months after I replaced by TC bushings and tie-rod ends, my front end shimmy returned.
Jason
'95 240sx SE
jmauld is offline   Reply With Quote
Old 06-23-2004, 07:48 PM   #15
AKADriver
AKADriver's Avatar
It was actually the tie rods that caused it, but in addition to that, the boots at the ends of the rack split and the seals at the end of the rack failed... PS fluid leaking all over.
Old 06-23-2004, 12:18 PM   #16
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
where do you take the car to have the old tc bushings out and put the new ones in?? the dealership will only replace the whole thing.
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 06-23-2004, 12:40 PM   #17
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
You just need to find a machine shop with a hydraulic press.
thelinja is offline   Reply With Quote
Old 06-23-2004, 01:21 PM   #18
Natty
Bah, a vice, some lube, and determination should be enough. Stock/Nismo are easier than whitelines too boot.
http://www.240sx.org/atlanta/TC_bushing_install.htm
Old 06-23-2004, 04:37 PM   #19
GamblerZ
GamblerZ's Avatar
GamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enough
Send a message via ICQ to GamblerZ Send a message via AIM to GamblerZ Send a message via MSN to GamblerZ Send a message via Yahoo to GamblerZ
That's what my wife said. DOH!
Visit WTI - WestTexasImports.net
GamblerZ is offline   Reply With Quote
Old 06-24-2004, 12:58 AM   #20
twitchy
twitchy's Avatar
"machine shop"
like...just ask them if they have a press?
Old 06-24-2004, 11:23 PM   #21
andrave
andrave's Avatar
I dunno, I went to a machine shop.
the kind of place that says "mckneely machine" on the front of the building, has metal working and machining equipment inside.
Old 06-24-2004, 11:44 PM   #22
S14DB
AFC #1
S14DB's Avatar
I was to lazy to get new ones pressed in. So, I just bought pillow ball rods and called it a day.
Old 06-25-2004, 12:25 AM   #23
citizen
citizen's Avatar
citizen is making a name for him/her selfcitizen is making a name for him/her selfcitizen is making a name for him/her self
Send a message via AIM to citizen
how was it hard to get out with a vice? i did mine with a hammer, and that wasn't terribly dificult in itself.
citizen is offline   Reply With Quote
Old 06-25-2004, 09:01 PM   #24
andrave
andrave's Avatar
my oem bushigns had thick metal shells that wouldn't come out.. I nearly broke my vice trying...
it was money well spent.
Old 06-26-2004, 08:12 PM   #25
andrave
andrave's Avatar
never mind I just put a set in with a vice.
getting the shells out was hard but I hammered a screw driver between them and the rod end.
