Old 06-24-2004, 01:39 PM   #1
Shin_Kudo
Shin_Kudo is an unknown quantity at this point
Car sometimes won't give up key
This is a problem I've been having for a while with my '95 base model. Sometimes, I park her, put her in park, pull up the e-brake, and turn off the car, only to find that the key won't go the last click and come out of the ignition. Usually, it's solvable by startin the car again and shifting back into D, dropping the brake, and ther reversing the process. It, however, sometimes takes several tries. Also, turning the wheel seems to have no effect on the key. (Removing the possibility that it's a wheel lock thing)
Any idea what's going on?
'95 240SX Base Pearl White
Shin_Kudo is offline   Reply With Quote
Old 06-24-2004, 02:47 PM   #2
GamblerZ
GamblerZ's Avatar
GamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enough
Send a message via ICQ to GamblerZ Send a message via AIM to GamblerZ Send a message via MSN to GamblerZ Send a message via Yahoo to GamblerZ
It sounds like perhaps the tumblers in your ignition are worn or broken causing the key not to release. Otherwise, can't help you since you have an auto.
Visit WTI - WestTexasImports.net
GamblerZ is offline   Reply With Quote
Old 06-24-2004, 02:56 PM   #3
kandyflip445
kandyflip445's Avatar
Go to wal-mart where they have the key copy place, they have some graphite lube there. Follow the instructions on the tube.
My 240 vBgarage
Old 06-24-2004, 02:57 PM   #4
GamblerZ
GamblerZ's Avatar
Lube for locks that is...
Old 06-24-2004, 03:06 PM   #5
kandyflip445
That's what graphite lube is for...........
My 240 vBgarage
Old 06-25-2004, 10:26 AM   #6
GamblerZ
GamblerZ's Avatar
No sense of humor
Old 06-24-2004, 09:01 PM   #7
Shin_Kudo
Wow, is that all it is? I was a little concerned that there might be a problem, as my car is getting its Manual put in as we speak.
Old 06-24-2004, 09:41 PM   #8
papershot
papershot's Avatar
papershot is an unknown quantity at this point
Send a message via ICQ to papershot Send a message via MSN to papershot
I used to have that problem with my 95 SE. My key would get stuck and I couldnt turn it at all though. All it took was shaking the steering wheel a little bit to dislodge the key. Doesn't happen a lot though..
papershot is offline   Reply With Quote
Old 06-24-2004, 09:45 PM   #9
Salty_X
Salty_X is an unknown quantity at this point
Autos have an electronic lock that won't let you take the key out unless the car is in Park. More than likely that's your suspect. Try wiggling the shifter around in Park to see if the key will come out. If not, you might want to try removing the electronic lock altogether.
Salty_X is offline   Reply With Quote
Old 06-24-2004, 10:05 PM   #10
Sanchi
Macadamia Nut
Sanchi's Avatar
Sanchi is an unknown quantity at this point
FUnny i got that problem too.. mines a 5speed, but like once in a blue moon it will do it couple times in a row then stops!! strange... very strange ill try that lube hehehe!!
"Fear is the path to the Dark Side..., Fear leads to Anger, Anger leads to Hate, Hate leads to Suffering…" -Yoda
Sanchi is offline   Reply With Quote
Old 06-24-2004, 11:59 PM   #11
kandyflip445
I used it in all of my cars locks. Made a world of difference in the drivers side door and the ignition.
My 240 vBgarage
Old 06-25-2004, 01:01 PM   #12
tastyratz
tastyratz's Avatar
tastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to behold
Send a message via AIM to tastyratz
key lock capture system attached to your steering column :-)
tastyratz is offline   Reply With Quote
