Old 07-02-2004, 11:20 AM   #1
RiceEata
RiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to behold
Caliper size question, and do s14 5 lug rotors fit s13 calipers?
Can i use s14se 5 lug rotor with my s13 calipers?
I know the rears should fit but how about the fronts.
And what does 30mm , 28mm , and 26mm caliper mean?
I have roja fomula 5's and the measure from where the rim meets the hub to the back face of the rim is 1" about 25mm. So if a 30mm caliper is measured from the hub, i don't think, these rims will even clear 26mm calipers.
I seen pix of 350z's with these rims...
Thanks in advance...
RiceEata is offline   Reply With Quote
Old 07-02-2004, 11:40 AM   #2
Tubed4evr
Tubed4evr is an unknown quantity at this point
Just to clarify. 26mm and 30mm refers to the rotor thickness and is not a measurement from hub to outside caliper face. The 30mm calipers provide less wheel clearance than the 26mm calipers simply because they have slightly wider body to accommodate the thicker rotors.
Sorry I don't know how much back spacing (what you measured) you need to clear either caliper.
Ryan
Tubed4evr is offline   Reply With Quote
Old 07-02-2004, 10:45 PM   #3
RiceEata
Thanks for the info, I'll try searching for back spacing specs...
Old 07-03-2004, 12:30 AM   #4
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
they have another thread (z clearance query) is the name of it discussing this exact problem. Im going to take the exact demensions and filll in diagrams to make it easy. Im using the stock 4lug SE rims and i know they are absolutely as small as u can get with still clearing
nlzmo400r is offline   Reply With Quote
Old 07-03-2004, 05:49 PM   #5
omen2853
omen2853's Avatar
omen2853 is an unknown quantity at this point
yes theyll fit. i did it on my car when i went 5 lug. you gotta jiggle them in a little but they fit.
omen2853 is offline   Reply With Quote
Old 07-03-2004, 06:34 PM   #6
RiceEata
Thanks, are you talking about the s14 front rotors?
