Old 09-28-2014, 08:58 PM   #1
zodpowercy
zodpowercy is an unknown quantity at this point
Can the s15 temperature gauge work with a s13 redtop engine ?
And if it is possible How ?
zodpowercy is offline   Reply With Quote
Old 09-28-2014, 11:20 PM   #2
Primo's Silvia
Primo's Silvia's Avatar
Primo's Silvia is an unknown quantity at this point
U mean the sensor? Or u mean the actual guage on the cluster????
To my knowledge the actual tempature sensor's on s13-s15 rb's are all the same including the tempature sensor switch.
Originally Posted by adams 02rs View Post
Here yee have found zilvia...WELCOME TO HELL.
Primo's Silvia is offline   Reply With Quote
Old 09-29-2014, 05:43 AM   #3
zodpowercy
Thanks Primo for replying.
I am talking about the actual gauge on the instrument cluster .....
Sensor is ok -i even tried a few different sensors (z32 etc... no luck at all)
Old 09-30-2014, 11:55 AM   #4
zodpowercy
Anyone knows how to make it work ? The guy that did the harness said temp gauge in the s15 instrument cluster gets a signal from the s15 ecu.Is that true? IS there any way to make it work ?
Old 09-30-2014, 12:07 PM   #5
S14DB
AFC #1
S14DB's Avatar
You need to replace the 1 wire temp sender on the engine with a S14/15 version. The resistance is different on the S13.
Old 09-30-2014, 01:42 PM   #6
zodpowercy
The temp sender was replaced with a s15 version but it still did not work.As i said the engine is a redtop s13 ,the harness and ecu are the stock s13 ones but are installed on a s15.
If the sender is connected directly to the meter should it work ? Is what i was told (that a s15 ecu and harness is needed for the temperature gauge to work) bullshit ?
How the temp sender wire should be connencted on the temperature gauge/instrument cluster ?
Old 10-02-2014, 04:02 AM   #7
zodpowercy
Any ideas ? Am I the only one that uses a s13 redtop on a s15 ?
If the temperature sender of an s15 is connected properly with the instrument cluster but without the s15 ecu could it work ?
Old 10-03-2014, 01:37 AM   #8
zodpowercy
Now i think i got it.
I asked the guy if he changed the 1 wire temp (dash) sensor and he did not.....probably thats the problem.
If i use a s14 1 wire temp sensor would it do the trick ?
I found only a s14 (25080-89907) sensor and not something specific for a s15
Old 10-03-2014, 11:19 AM   #9
S14DB
AFC #1
S14DB's Avatar
Yes, this is what we have been saying. The S14/S15 are the same. S13 is different.
Old 10-09-2014, 06:33 AM   #10
zodpowercy
It worked like a charm !!! I bought from a nissan dealeship an oem sensor for 23 euro (30 dollars ) and with an additional resistance it worked perfectly !!!!
Many many thanks without the information here the interior of my beloved s15 would look like shit...
