Old 10-16-2014, 08:57 PM   #1
240SXK
240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light
Exclamation SR20VET rwd VVL intake manifold, z32 calipers, aerocatch
i also got a pair of z32 N/A aluminium calipers $150 plus shipping and aerocatch hood latches with keys (real) for $80 shipped. the calipers look a bit rough but they came from a running z32 car i once had, i just never bother to clean them but all hardware comes with them. even pads
240SXK is offline   Reply With Quote
Old 10-16-2014, 11:28 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Questions
Does this clear the hood?
What injectors fit that rail/collar combo? ID1000?
What flange for throttle body is that? Throttle included?
Old 10-17-2014, 12:03 AM   #3
240SXK
Questions
Injector dynamics and others that are similar. i fitted ID1000 on it for my setup.
the flange for the thottle body is drilled for the factory throttle body and bolt pattern but comes pre machined for up to a 70 mm bore. the SR20VE throttle body is included with this.
the thottle body didn't clear the hood on my setup, i have nismo engine mounts that raise the engine about 3/4" from oem position, if you run different aftermarket mounts that have the benefit of lowering the engine you most likely will, i haven't tried it since my oil pan hangs low and the roads around here are too dangerous to lower the engine any more.
Old 10-19-2014, 08:36 PM   #4
Face Man
Face Man is an unknown quantity at this point
Will you sell the valve cover?
Face Man is offline   Reply With Quote
sr20ve, sr20vet, vvl, z32
