PART OUT ProAM S13 VERT/APEXI/VQ35 swap/VOLK/COSMIS/AERO/SPARCO/KNUCKLES/MORE!
Location: North GA Contact: Call, text, PM or e-mail. 770-seven1four-0134 [email protected] Title: Clean GA title in my name Payment type: Cash or paypal Chassis: $4500 rolling on stock suspension and brakes 1993 Nissan 240sx convertible NO RUST!. Weighed 2560 lbs fully assembled New base/clear scion Xb paint/ Murasaki aka purple VIS front and rear wide body VIS super made body kit TRA rocket bunny wing, real 350z side view mirrors Stripped and shaved chassis work Interior painted black Tube front and rear frame with crash bars 2014 formula drift/pro am spec cage 1.75" tube/ .120 wall Lexan windshield Sparco trunk latches Aeromotive stealth 6.1 gallon fuel cell, internal pump can support 600hp I believe. -6 AN hose, fittings and Moroso filters for breather/roll over tubes Moroso hood pins Custom aluminum side mount seat bracket for driver side G force weld on quick release Custom steering column with 3/4 DOM .120 tube, built in safety in case subframe is pushed back in a wreck. Hydro ebrake mounting location on side of trans tunnel. Welded 3/16" steel 350z dash 350z clutch pedal assembly, 350z brake pedal 350z gauge cluster with auto meter gauges molded in Auto meter pro comp rpm, water temp and oil psi Moroso switch panel Countersteer Motoring race car body harness. Fully hand built, 3 wires running from the dash to the rear only and 4 wires other than engine harness running forward of the dash. 14 lb Shurken battery Custom battery mount with 1/8' steel plate, FD legal Moroso alternator relay Moroso battery kill switch LED front and rear brake light strip Rear fire wall panel Countersteer Motoring tucked brake lines in engine bay 300zx brake master cylinder S13 brake booster painted wrinkle black Crazy bright head light bulbs High density roll cage foam G force 4 panel rear view mirror Rear subframe collars VQ35DE engine and trans: $2300 2004 Nissan 350z vq35de with 85,000 miles when swapped in a year ago from a automatic. ZERO LEAKS, DOES NOT BURN OIL, PERFECT! Tomei cams Tomei springs and retainers Competition clutch stage 4 Competition clutch light flywheel Suspension and brakes: Front and rear (S14) 5 lug with Arp extended studs $350 300zx aluminum front brakes, rotors, and stainless braided brake lines $200 Exterior/interior: Sparco Evo seats $360 each one has hole size of a dime Sparco steering wheel $150 Gforce 4 point harness $120 Other: J30 VLSD WELDED, casing has been wire wheeled, painted black, 180sx high fluid capacity diff cover, new output shaft seals, steel tab removed for better exhaust clearance, and solid diff bushings $200 Weapon R coolant over flow tank, modified to work properly. $50 Countersteer Motoring 3.5" aluminum catback exhaust. S13 chassis $300 Wheels/tires: Cosmis Racing XT-005R 18x10 +20 x2 rear spares $400 Here is a link to a video and more of the car in action. This video is from when the fans broke so I ran no hood in the heat of Orlando FL. https://www.youtube.com/watch?v=FyXu_HsYgbY ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Always have something for sale, check my threads. Ships in 24hrs or less! Last edited by dil han; 01-30-2015 at 05:57 PM.. |
#4 | |
All you need are two big inner tie rod spacers like PBM, GKTECH or godspeed. Everything bolts on.
Always have something for sale, check my threads. Ships in 24hrs or less! |
Thanks man. Already sold some things! Come get this ish!
Thanks a lot. Coils and tails are sold.
Part list updated and prices dropped. Lets get this swap and shell sold.
#15 |
Sold all the swap parts. Really looking to sell the shell and the motor/trans. I'll keep everything else.
#24 |
![]() Join Date: May 2009
More info on the engine, is back to.stock or is it coming with blower? What were you using for engine management and engine mounts driveshaft price?
