Old 03-12-2015, 04:39 PM   #1
QuickSpoolSR
QuickSpoolSR's Avatar
QuickSpoolSR will become famous soon enoughQuickSpoolSR will become famous soon enoughQuickSpoolSR will become famous soon enoughQuickSpoolSR will become famous soon enough
SR Built s14 sr20det nearly full swap
NEW PRICE $2000 shipped to continental US
The bad: has a top end noise, the shop it's at told me it's the lifters, I'm just done dealing with this engine.
History: was stock drove it for about a year, spun a bearing having it tuned, was rebuilt with bc rods cp Pistons, bc 264/264 cams, acl bearings, it drove for 1300 miles and spun a bearing again, just got done having it rebuilt again, some new parts, currently has under a mile on it. full list of parts:
S14 zenki sr20det engine and trans
All sensors, all accessories, coil packs, igniter, ratty harness but works
Cp Pistons
Bc rods
New remanufactured stock crank with matched acl bearings as close to stock clearance as possible
New bc valves, new valve guides and seals
Bc 264/264 cams
Brand New dynatec lifters(supposedly bad)
Bc springs and ti retainers
New Apexi head gasket
New oem oil pump
New timing chain full kit
New gaskets where applicable
five-o 750cc injectors
Spec street flywheel
Will not come with turbo or exhaust manifold, clutch, or ecu
By disconnecting the coil packs one by one the sound does not go away, which is another good sign that it's not a bearing, also the oil is immaculate no metal or anything, it runs and drives, I drove it around the block, I just don't think it sounds right and I don't trust it. The car is located at a shop in Des Moines Iowa if you would like to hear it in person I will post a link to a video of it running.
I'm sure there are gear heads on here who can probably get this thing running like a top.
Call or text preferred
515-249-5146
John
QuickSpoolSR is offline   Reply With Quote
Old 03-12-2015, 05:08 PM   #2
QuickSpoolSR
http://youtu.be/puGSJL6Nebg
Old 03-13-2015, 11:05 AM   #3
QuickSpoolSR
Also forgot to mention the vtc was eliminated it has s13 cams and gears
Old 03-16-2015, 09:47 AM   #4
QuickSpoolSR
Price drop $2500
Old 03-19-2015, 04:04 PM   #5
QuickSpoolSR
Buyer flaked, price drop $2,400...
Old 03-19-2015, 04:05 PM   #6
QuickSpoolSR
Will include apexi power fc tuned to this setup for an even $3k
Old 03-22-2015, 05:12 PM   #7
QuickSpoolSR
$2300 cant believe there isn't more interest
Old 03-24-2015, 03:28 PM   #8
QuickSpoolSR
$2200 price drop I'm $650 under stock swap price lol
Old 03-24-2015, 03:32 PM   #9
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Wow. Someone needs a deal. Come on people.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 03-25-2015, 09:27 AM   #10
QuickSpoolSR
$2,100 bump, this is as low as I'm gunna go before I just part it
Old 03-25-2015, 10:32 AM   #11
5280VertDET
Throw it on ebay, for BIN at 2300. Someone will buy it if you can get a freighter to ship easily.
Old 03-25-2015, 05:32 PM   #12
QuickSpoolSR
Will do thanks for the tip
Old 04-06-2015, 10:06 AM   #13
QuickSpoolSR
$2000 shipped #fuckit this week only
built, s14, sr20det, swap
