Weird noise from the rear
Lately I've been hearing this sound from the right side of my rear. I thought it was the tire that was wearing out, but I replaced it with new ones and I still hear it. I hear it more especially when I make a right turn. Does anyone have any ideas on how to fix this? I have a 90 s13 with vlsd. Could it be the diff making the noise? I'm not sure. Any help is appreciated. Thanks.
![]() Join Date: Aug 2002
Ya tony get under and look lazy ass. First u need to get a jack in order to get under and look though.
Bring it by my house next sat and we can look. buy a jack first as mine is not the best. Ill be working on my car anyways dumb exaust leak after last nights escapaid. And brandon is coming up to do wiring. |
![]() Join Date: May 2003
what does it sound like?? is it a thump or clunk.. or more of a WHOOSHING or whowhoowho sound.. i got a whowho sound and it was my diff fluid low.. . check the fluid.. could be low...
![]() Join Date: Feb 2003
![]() Feedback Score: 7 reviews
isn't expensive..jus gear oil. U might as well change it if ur gonna add some since it's somewhat pointless to add new to oil diff fluid unless u recently had new fluid put in. Alsi check for n e leaks since ur fluid is low and we all know it doesn't magically dissappear. Easy to add..i believe there is a 1/2 inch plug near the top that u take off and from there u can add some. Correct me if i'm wrongs guys. if you plan on changing it though u can take off the plate (held by several bolts) and it all should come out. Before you put the plate/cover back on make sure both surfaces are cleaned..use a razor blade to scrape the old gasket off. Find some of that rtv/silicone/sealent stuff..high temp and squeeze a small amount around the diff and use ur fingers to spread it out then bolt it back up. Then u can add more fluid through that hole (that hole is also used to check the fluid level so u might want to do that first)
i hope this is somewhat helpful info.
89 240sx Coupe |
my rear right side clunks too
![]() when is brandon gonna come up to daly city? bish! |
#8 | |
hahahha David is GHEY! yeah you heard it right! lol naw im just playyen man.. shure ill come up to DC sometime, just as long as i got a place to stay! haha BISH NYUGGUH! ![]() brandon
