Old 07-30-2015, 05:04 PM   #1
tomatolord
tomatolord is an unknown quantity at this point
Consult connection not working
did the engine swap from a 92 to a 96 engine.
note we did got this car in this condition so the old owner had given up as well.
engine starts
runs rough
cleaned maf
replaced map
no vacuum leak (did a boost test, did a spray check test, did a smoke test)
ok had this conzult sitting around Time to hook it up.
NADA on the setup..
here are the wires...
the green goofy one is the ground
tomatolord is offline   Reply With Quote
Old 07-30-2015, 06:08 PM   #2
ultimateirving
ultimateirving's Avatar
If your sure the wiring is correct then try shielding some of those wires. I felt like my consult wouldn't connect to my ECU if there was a lot of electrical noise
Z32 with lq4 swap
Old 07-31-2015, 04:28 PM   #3
Juan@Fontananissan
Juan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura about
Make sure that the consult plug is pinned out correctly and that it has power & ground.
also try using the PLMS cable instead, I've found that to be the best working cable (right next to the Bltazt cable) for any Consult-II work.
Competition Engines & Dyno Tuning.
(951)708-1648 | [email protected]
Juan@Fontananissan is offline   Reply With Quote
Old 08-01-2015, 09:25 AM   #4
cotbu
cotbu's Avatar
verify the consult wires pin location from port to the ecu plug, via continuity test.
try external power and ground if you still can connect, dropping a connection is what usually happens when there's noise, but with koeo you should still be able to connect.
we can fix a noise issue later.
