Old 03-16-2016, 11:03 PM   #1
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
SR heats up at idle, cools while driving
I have an SR that heats up at idle and keeps climbing but when i i get moving it starts cooling down. i dont think its a warped head or headgasket issue because itcools itself back down and the coolant doesnt geyser out of the rad cap when i open it
has an aluminum rad and a FMIC
I read it might be a clogged cooling system, air in the system, a half stuck thermostat or my cooling fans.
im gonna get a coolant flush. i tried to bleed the air today but i might not have done it right (removed the bleeder screw by the exhaust side of engine)
anyone got any input on this?
kyral is offline   Reply With Quote
Old 03-16-2016, 11:29 PM   #2
jr_ss
Are your fans working? They all heat up at idle, but usually a radiator fan/s turn on you cool them off.
Old 03-17-2016, 06:20 AM   #3
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
You have air in your system, I'd assume that if you revved your car at idle it'd probably cool down as well. My car had the same issue and it turned out to be a cracked coolant line under my intake
[email protected]
hanzbrady is offline   Reply With Quote
Old 03-17-2016, 06:32 AM   #4
zenkicpe
zenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud of
Tip on burping air out of your system..
Pull your car up on ramps or put blocks under the front tires or park on a decent incline so that the radiator is the highest point. Find a funnel that will fit snugly into the radiator neck. Fill funnel about half way up with coolant. Start car and let idle, the air will burp up and out of the funnel as it works it way around to the radiator. Massage the radiator hoses at it warms and blips the throttle every now and then.
zenkicpe is offline   Reply With Quote
Old 03-17-2016, 06:56 AM   #5
hanzbrady
hanzbrady's Avatar
They also make a tool that you attach to the radiator that pressurizes the system pushing all the coolant out then you can basically vacuum in your new coolant.
[email protected]
Old 03-17-2016, 07:50 AM   #6
KAT-PWR
KAT-PWR's Avatar
KAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really nice
This is by far the best tool I've used
MRP Manufacturing
KAT-PWR is offline   Reply With Quote
Old 03-21-2016, 07:25 AM   #7
Tucker240
Guest
Posts: n/a
--Deleted--
