turbo do u wana play?
hey guys i got me another t25 and it spins nice..but it gots a lil lil tiny play in it....is that bad......and rite now it doesnt boost.....and it makes wierd noises like the fins are messed up or something like that...but it does it once and while..iono help me man.....
![]() Join Date: Jan 2003
![]() ![]() ![]() ![]() Feedback Score: 6 reviews
What the hell are you asking? Why are you asking it like this? And do you speak english?
Steven- "You don't know me, but I am better than you." |
ok im sorry for putting it in a way that you dint understand......
this is my third turbo.....i bolted it up and ran it and it ran fine...for about 30mins,,,,,i had boost and my blow off valve was going off like it should....then i turned the car off. and i went in the house...when i came out to go to the mall and started to drive it again...i was no longer feeling that boost. and when the bov went off it dint sound like it should...it was like a low peep noise....then i thought something was wrong..when i kept driving it..it started to make this rattling noise that i have heard be for in my old turbo..it was kinda of a low rattling noise..like change inside of a dryer...like my turbo fins are either rubbing or something like that...then when i look at my coolant resevior tank it was a lil lower then usual. i have no leaks or nothing...so is this sound my turbo dying...cause the last time i heard this soudn it was very loud and when i checked my t28 blades were stuck and it dint even spin any more.... i check the t25 i have still spins...but feels like it has a lil alil bit of play in it...is that bad.....its not real noticeable cause its real small but u can feel it move jus a lil bit...so iono ...hope this helps a lil more. |
![]() Join Date: May 2003
Do you have sufficient oil flow to the turbo? If this happened before, that may still be the cause...
- Brian
www.KA24DEvelopment.com |
![]() Join Date: Apr 2004
Ok Im almost positive your headgasket is leaking and the sound you are hearing is detonation. Have you done a compression test yet? You've had the same problems with all 3 turbos, maybe its not turbo related.
![]() Join Date: Jan 2004
While you do the Headgasket, I suggest you do a head rebuild. The SR will be a lot more reliable and boost happy.
96 all suspension s14 SOLD 90 s13 coupe - SOLD Currently rocking 2002 BMW M3 w/ custom suspension. ![]() ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only. |
well the 3 turbos that have gone.....out of all of them the car drives fine...but it jus that the turbo keeps gettin messed up....is it that i dont have good oil to the turbo or no coolant to the turbo or sumthin or do you guys realy think its my head gasket...what are some other symptoms that i can see that tells me my headgasket or head is going.......cause when my turbo is messed up i drive it like that and the car and the motor drives fine...just feels like i have an sr20de with no turbo you know..but hit me back....thanks guys
