Old 09-21-2017, 11:22 PM   #1
Notfast55
Notfast55 is an unknown quantity at this point
Exclamation Blue smoke when idle and pulling out from stop
My 93 240sx is puffing blue smoke when idling and pulling out it puffs a big cloud, also was overheating but i took the thermostat out and kinda temp. Fixed it
Notfast55 is offline   Reply With Quote
Old 09-22-2017, 07:35 AM   #2
simmode1
simmode1's Avatar
1) I'd stop driving it until you figure it out to avoid causing more damage.
2) Removing the thermostat isn't a fix. You just removed the car's ability to TELL you it's overheating & regulate coolant flow.
3) What engine is this?
4) My guess would be headgasket here, but I could be wrong.
"Simplicity is the key to brilliance." - Bruce Lee
Old 09-22-2017, 08:00 AM   #3
tuzzio
tuzzio's Avatar
Does it smoke on start up? If so, likely valve seals.
If not, likely rings.
Do a compression and leakdown test and bring back data. Bitches love data.
Old 09-22-2017, 12:29 PM   #4
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
step 1: compression test
step 2: head gasket test (you can purchase the kit at most auto parts stores)
step 3: ??????
step 4: PROFIT
Old 09-22-2017, 01:17 PM   #5
Notfast55
I cant stop driving it till monday then hopefully i can adress these problems but i had a feeling it was ring or headgasket but if she blows guess it a key time for an rb swap 😂
Old 09-23-2017, 08:06 AM   #6
tuzzio
tuzzio's Avatar
What're you going to do when the RB blows up? Because it will.
Old 09-23-2017, 09:05 PM   #7
Notfast55
Probably correct the issue 🙃 but ka survived so im in no rush
Old 09-23-2017, 09:07 PM   #8
Notfast55
But the help pertaining to original issue was helpful so much appreciated to all
Old 09-24-2017, 07:12 PM   #9
rainbowhatch
rainbowhatch is an unknown quantity at this point
for now get some of the cheap headgasket repair in a can and refer to their instructions. should work fine for the next few days or more but definitely not a temporary fix.
rainbowhatch is offline   Reply With Quote
