Old 12-04-2017, 08:32 PM   #1
Garage Skidz
Garage Skidz is an unknown quantity at this point
SR SR20det ring gaps and bearing clearances
I cant seem to find any info on what ring gaps and main/rod bearing clearances to run. if there is a solid thread on this stuff please let me know cause I haven't found one yet.
So does every one just run OEM clearances and gaps, even on their higher power builds?
Build: s14 notch top sr20, 87mm bore Eagle rods, CP pistons, ACL bearings, 2871r .64 a/r, JTW s3 cams, and shooting for 350-400whp.
so I'm just thinking wouldn't you wana run a slightly bigger bearing clearance and ring gap for more than stock power? I plan to up the power later so I would like to accommodate for that before I put it in.
the ring set I have for the pistons (wiseco 8700XX) comes with instructions that gave me a formula for the ring gaps. they came out to be .0017 for the top and .0018 for the bottom ring. I believe these are within the stock spec, is this good or bad? I just don't want to crack a piston.
if this is something I can find in another thread I apologize just looking for some definite info on my particular setup. Thanks
Garage Skidz is offline   Reply With Quote
Old 01-20-2018, 11:33 PM   #2
lucas240sx
lucas240sx is a jewel in the roughlucas240sx is a jewel in the roughlucas240sx is a jewel in the roughlucas240sx is a jewel in the roughlucas240sx is a jewel in the roughlucas240sx is a jewel in the roughlucas240sx is a jewel in the roughlucas240sx is a jewel in the rough
Bump this up
I too am curious
Sent from my SM-G955U using Tapatalk
lucas240sx is offline   Reply With Quote
Old 01-21-2018, 05:25 AM   #3
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
Its all covered in the “engine mechanical” section of the FSM.
sidewaysil80 is offline   Reply With Quote
Old 01-21-2018, 09:19 AM   #4
lucas240sx
I have the s14 fsm printed out.
It says .008-.012 top ring
Untouched my wiseco top ring is it .008
Wiseco wants 86.5mm / 25.4= 3.405
3.405 x .005 = .01702 top ring
3.405 x .0055 = .01873 2md ring
I've read ppl say 2nd ring needs to be .004-.008 bigger
Old 01-21-2018, 05:53 PM   #5
tuzzio
tuzzio's Avatar
Call wiseco and see if they recommend this and proceed.
Old 01-21-2018, 06:59 PM   #6
lucas240sx
I'm gapping to wiseco spec
Old 01-21-2018, 07:09 PM   #7
sidewaysil80
I would call CP, I'm pretty sure the piston:wall clearance would have an effect on rings. Since it's their piston and subsequent measurement, it wouldn't hurt to double check. BUT, if both Wiseco and CP have the same clearances, that's a moot point. But really ring gap is only part of the equation.
Old 01-21-2018, 06:51 PM   #8
sidewaysil80
As far as bearing clearances it's pretty well documented that unless you are line boring, stick with factory nissan bearings/specs.
Old 01-22-2018, 08:42 AM   #9
gaz_moose
gaz_moose is an unknown quantity at this point
not saying that I know what im talking about but,for ring gaps I would go on the large side as at worst it would just give you abit of extra blow by. too tight and you would get the rings binding up. I would use the piston/ring manufacturers settings.
that is assuming you plan on beating on the engine regular.
gaz_moose is offline   Reply With Quote
Old 01-23-2018, 07:55 AM   #10
jedi03
+1 on following the piston manufacturers suggestions...I followed CPs with their pistons...2nd owner still beats on the engine over a year and a half later...they look at how the piston is normally used and calculate to make sure ring landings don't crack (binding piston ring)
Old 01-23-2018, 08:43 AM   #11
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Correct. Unless specifically noted in special applications, always follow what the piston manufacturer suggests.
Old 01-23-2018, 09:53 AM   #12
TheRealSy90
TheRealSy90's Avatar
Do you personally tend to go to the looser or tighter side of the tolerance?
Such a good signature.
Old 01-23-2018, 10:29 AM   #13
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
Depends on end goal. Lots of track use (trackdays, long drift session) slightly looser in general terms due to the major buildup of heat and expansion
JE pistons has all the calculations and recommendations on their site. Just select which piston and it should have all the info (including bearing clearance if you also bought their rods). There is some math involved which take into account bore dimensions for instance.
RalliartRsX is offline   Reply With Quote
Old 01-23-2018, 10:59 AM   #14
Garage Skidz
Thanks all for the replys. Im probably going with the .017 top and .018 bottom gap. that should be good for 15 to 20 psi with a 2871r for street use.
Old 01-23-2018, 01:17 PM   #15
TheRealSy90
While we are at it, what's everyone's preference for rod/main bearings as well as clearances? I know there's a lot of variables involved such as if certain machining steps are performed or not.
Personally, I'll always go with OEM Nissan bearings, sized off of the markings that are stamped into the block and the crank, preferably WPC treated. But once any of that gets machined those are moot and needs to be properly measured out. However, i'll never personnaly run a crank that's been machined on the bearing journals as I believe they are surface treated and hardened, and you then lose that hardened material.
I've never been a fan of those ACL "race" bearings that just come one size fits all, no wonder people spin rods so often with those.
A friend of mine that builds fwd sr's often always goes with "calico" bearings?
Old 01-23-2018, 01:30 PM   #16
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Calico is a coating company. They're the company that Mazworx uses. Also worth noting every Mazworx and almost every Real Street build runs ACL Race bearings including my own engine, hell my SR even has a cut crank. The race bearings also come in 3 sizes STD, .025mm, and .25mm. These bearings are obviously most at home in a perfectly round hole that's machined with an aftermarket bearing in mind.
At the end of the day with modern manufacturing processes every bearing from every company is damn near identical in performance. I would comfortably use any of the big 3's (ACL, King, Clevite) race bearings interchangeably, it's all personal preference.
[email protected]
hanzbrady is offline   Reply With Quote
Old 01-23-2018, 01:34 PM   #17
TheRealSy90
Thanks for explaining all that lol, been a while since I've shopped for bearings, I remember now that Calico'd Clevites were his preference.
In regards to Calico and WPC, I assume if one was planning to get their bearings of choice WPC treated, then there would be no gains from having them Calico coated before the WPC treatment? Even though WPC says they can treat wear coatings as well and that it's more beneficial than non-treated coatings.
I haven't actually had parts WPC'd yet but it's super appealing, would love to do a new build with WPC on every internal part haha.
Old 01-23-2018, 01:41 PM   #18
hanzbrady
hanzbrady's Avatar
Hmmm that's some internet science that's a bit over my head to be honest, thinking about multiple treatments and coatings and how they interact with each other hurts my head.
[email protected]
Old 01-23-2018, 01:41 PM   #19
RalliartRsX
Trader Rating: (32)
King is what I will recommend (And what is going in my VET build). Crank and mains have been measured and in spec, so the standard size should suffice (in my case)
Old 01-23-2018, 01:44 PM   #20
hanzbrady
hanzbrady's Avatar
Nice!
I personally have ACL mains and King rods, I was more worried about what was in stock and available haha.
The King bearings are great and what we almost exclusively run for Subarus since they're the only company that makes an oversized outer diameter main bearing with a standard inner diameter for straightening the line bore without having to mill the faces of the case halves flat.
[email protected]
Old 01-23-2018, 01:48 PM   #21
RalliartRsX
Trader Rating: (32)
Not knocking ACL, as it seems they work. But I am concerned with the QC on their bearings. According to the internet, they are hit or miss (or in Mazworx and a litany of other (SR20) cases like yourself hanz, they seem to be on target more than off target). However, I have seen first hand the quality and measured/consistent specs of the Kings, so they will be the bearing of choice for me. Just going to go with what I have experienced
In addition, the King bearings are not much more expensive in the grand scheme of things. So that is my choice
P.S The internet is a shitty place which sway opinions (and not necessarily rooted in facts or without bias) too far one way at times hahahahahah!
Old 01-23-2018, 05:46 PM   #22
TheRealSy90
Slightly on topic but also off topic, cool read about how they made bearings for old engines that don't use a shelled bearing: http://www.roadandtrack.com/car-cult...bitt-bearings/
In regards to piston rings, it blows me away how many people throw rings on, install pistons and send it. Never thinking about ring gap.
bearing clearance, built sr20, piston rings, rings, sr20det
