Power FC abilites?
Althogh this is kind of a blanket statement, but what can the power fc not do. I heard that it can detect all sorts of engine problems, like sensor failure. What can it not detect?
![]() Join Date: Jan 2004
Main reason is for easier and better tuning.
96 all suspension s14 SOLD 90 s13 coupe - SOLD Currently rocking 2002 BMW M3 w/ custom suspension. ![]() ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only. |
Don't worry, I checked the site, but it says on their that it can check to see if a sensor is in use or malfuctioning. I was asking if I can do this for all sensor and engine parts? Also if you remove the MAS for a MAP sensor, where do you plug it in?
#6 | ||
thanks for the info. Does a MAP equpied jetro have more potential then say a z32 MAS with a standard fc? Also what about a drag-pro power fc? how does this compare to the jetro and the standard?
Yes, it has more potential then any maf. It is more precise, and has unlimited boundaries. As for a comparison between the two standalones, I believe the drag one is maf, and has a launch set, where you would be able to gun it in neutral and the rpm's will only go up to what you set it to. There is also a setting where when you shift, it only goes to a set rpm while never taking your foot off the gas. There is also one that is in between the drag and D-jetro, It starts with an L and it also uses map, I cant think of the name, I will have to ask my friend tomorrow. Unless you’re going for drag, I would go with the D-jetro, or the plain pfc.
