Old 10-21-2018, 07:50 PM   #1
Importtuning06
Importtuning06's Avatar
Importtuning06 is an unknown quantity at this point
JDM 89' 300zx TT 2+2 manual 60k miles fs/ft $8.5k
*It will need minor work to be driven* Looking to sell my JDM 89 300zx TT 2+2 with 60k miles. Shortly after purchasing the car directly from an importer I pulled the motor. I then did a 120k service to be safe, along with rear main seal, clutch, flywheel, z33 clutch fork, brass shifter bushings, valve cover gaskets, multiple deletes, pulleys, z1 silicone hoses, z1 metal lower rad pipe,2.5" downpipes and test pipes, Hicas delete, knockoff momo wheel, tomei shift knob, jw single popcharger, s2 ptu, new oem tps, upper front and rear strut tower bars, and I'm sure there is more. It now runs but will need a little work to be road worthy including bleeding the clutch, new plugs, and just tidying up the harness and vacuum lines. Nothing major. I have lost interest and basically do not have the time for it anymore. The car was resprayed in Japan prior to being imported but is not perfect. The interior is very clean with the exception of the drivers outer bolster. I'm looking to get $8.5k or possibly trade. Clean Virginia title. Located near Hershey, PA.
Importtuning06 is offline   Reply With Quote
Old 10-22-2018, 06:49 AM   #2
Tuffyswanson
Tuffyswanson is an unknown quantity at this point
You removed the original motor and replaced it with one with double the mileage? Just looking to clarify.
Tuffyswanson is offline   Reply With Quote
Old 10-22-2018, 07:53 AM   #3
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
He probably meant the 120K service the VG engine requires (all timing components and water pump last I checked).
RalliartRsX is offline   Reply With Quote
Old 10-22-2018, 10:47 AM   #4
Importtuning06
Correct. The "120k" service. Original motor is in the car.
Old 10-22-2018, 12:42 PM   #5
greenwood
greenwood's Avatar
greenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymore
lol how do you read man.
greenwood is offline   Reply With Quote
Old 10-22-2018, 03:38 PM   #6
Tuffyswanson
Not very well, but after a few beers I get it alright
Old 10-22-2018, 04:52 PM   #7
Importtuning06
Hahah it happens. No worries.
Old 10-22-2018, 11:06 AM   #8
Tuffyswanson
That's for the help. Op, nice car, and even nicer care.
