Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34. |
05-16-2020, 06:30 PM | #1 |
Got Tips? 15hrs at Road Atlanta in a Z31
Alright fellow Zilvia folks. Looking for people that have experience with Z31's. My friends and I picked up an 86 N/A that we'll be running in a Lemons race at Road Atlanta in December. If you don't know about Lemons, the main thing to know is the budget is tight. $500 is the max spending limit for the car and anything we do to it that isn't safety related. The car will run, has 250k+ miles, and is a 5spd.
Basically we'd like input on two things as of now: 1) What should we expect to break? 2) What would you be sure to do to your Z31 before hitting the track Open to any and all input, even if its just to call us morons for attempting this (we are).
86 300zx/90 240sx/97 240sx/96 LS400/03 350z -Shake N' Break Racing- |
05-16-2020, 08:47 PM | #2 | |
You're going to have a blast regardless. Ran RA in 15'. One rainy session and a couple of days worth of dry. Not a lot of help with the chassis here but best of luck. I'll see if I can't turn up some info for you. What room do you have left in the budget if you don't mind sharing. Are you pretty much tapped out already? I'm ignorant of class rules but what can you do with wheels/tires?
https://z31performance.com/forum/z31...or-road-racing Slotting the strut towers for negative camber seems like a worthwhile mod. http://xenonzcar.com/z31/issues.html Found that as well. Hopefully someone with firsthand experience will chime in. *edit* Ok so we're working with These? Quote:
I'd recommend; - New wheel bearings since 1), they're exempt from your $500 cap and 2) Guessing the car is in unknown condition. Reduction in rolling resistance as well as reducing hub temps around your brakes which are going to be getting warmed over already Rock Auto has them CHEAP - Slotting strut towers to gain some negative camber. It's free grip. - Whatever you can do to take some slop out of the suspension and steering. Balljoints are exempt so sweet. If it were me I'd grab some liquid urethane similar to this for $50 and pull the suspension components and make some new bushings. Could maybe get some motor and tranny mounts out of the deal too. - Cut the dust shields off of the rear brakes. Either grab some cheap ducting and incorporate it into the shields on the front brakes or remove their dust shields too. New pads all around (exempt) and brake flush with ATE Typ 200 or above. - clean/adjust MAF/AFM - Verify timing/advance a few degrees perhaps? what fuel are you running. Engine is robust. should hold up if you're running above 87. if 87... not sure long-term. - If there's money in the budget, generic cone filter on the intake maybe? something like this if you can swing it for a few bucks. kidding on that last one. Sweet! found a downloadable FSM for your car too. Could come in handy. http://xenonzcar.com/z31/FSM/1984fsm.php Last edited by NukeKS14; 05-17-2020 at 08:47 AM.. Reason: update |
05-17-2020, 03:41 PM | #3 |
Oh I'm definitely looking forward to it. So long as none of us catch on fire its gonna be fun hahaha.
So we definitely have some room in the budget. At the moment we have maybe $100 non-bs dollars or so but we were able to salvage a lot of parts to resell and have some "plausible stories". As far as the motor goes, its definitely high miles but it was a 1 owner car and from what we found inside it we think he was an aircraft mechanic. Hopefully that means its been maintained. Almost every bushing on the suspension is shot so we are definitely planning on addressing that. As for fuel we can run whatever is going to work best for us. Intake we were honestly just going to do a PVC pipe with a filter and some nipples for vacuum lines. Also going to find some cheap E-Fans to run. Definitely going to look into wheel bearings and check out the strut tower slotting, hadn't considered that yet. Also planning to do some things you can't readily see as well, like a new oe type clutch, spark plugs, stuff like that. On the subject of brakes, we were probably going to just do upgraded rotors and pads. Tires have to be shit basically. I think minimum treadwear is like 190. As for wheels we were just going to pick up some Z32 wheels for it and run those.
05-17-2020, 06:56 PM | #4 |
Sounds like a good start. You're most likely not going to see jack diddly from the intake, my dry humor gets lost on forums. Removing the cat on the other hand would make it a bit more free-breathing. Guessing since that's exempt you were going to just toss a straight pipe on it.
If you stuck to mid grade or above fuel I think you could advance the distributor enough to see some gains and still be safe. Since you'll have the tranny off already, had you considered a lightweight flywheel? Some more info on what flywheel and clutch combos are interchangeable between the VG30E(T), KA24DE, and RB20/25DE(T). Be careful here. the VG30DE(TT) looks like it's got a different bolt pattern\count (8 over our 6) and wouldn't work. You can source the RB20 flywheels for less than $150 on eBay all day long. They call it a white bunny setup for the KA engines. I'm running one myself. I've never heard of anyone putting it on a VG30E though. Seems plausable. I can grab pictures and take some measurements if you're interested. Stock ignition system seems pretty stout to 300/400 whp (just an aside.) Might do to toss a new rotor in there and clean off the points on the cap though with some good ol' 80 grit. As for the electric fan, I have a used OEM electrical fan out of an S14 240sx if you want it. You probably need something that's going to pull more air like out of an old Taurus or something similar though. |
