Old 09-07-2021, 09:26 PM   #1
Stealthyfish
Stealthyfish is an unknown quantity at this point
Garage Clean Out - Race Car Parts
Clearing my garage out for new projects. Shipping is not included and local sales are preferred. Everything is located in Atlanta, GA.
EXTERIOR:
S15 Headlights with custom bash bar - 650
S15 Custom metal fenders. S15 and S14 fenders were grafted together and professionally finished to re-create the OEM S14 body-line. Includes a +50mm Car Modify Wonder fiberglass flare - 1200
S15 Garage Mak replica front bumper - 300
S14 Origin Stylish side skirts - 300
MECHANICAL:
ISR LS engine mount adapter. Comes with T56 trans xmember - 300
2 qt Accusump with electronic switch , 10AN adapter, and 10AN Tee - 650
ISR LSx HGC Longtubes with DEI titanium exhaust wrap - 500
Fitech LS ECU with Wiring harness - 750
Fitech ECU ? compatible with 24x and 58x LSx reluctor setups
Fitech Engine Wiring harness - Fuel pump wire was shortened, otherwise wiring harness is intact
2x Precat O2 sensors
2x knock sensors
Fuel injector harness included
No ignition wiring harness
Electric Hydraulic Power Steering Kit - 400
Volvo S40 EHPS pump
OEM plug for power supply
80A breaker
OEM plug for signal-on
14 ft of -6AN braided line with fittings return line
12 ft of -6AN high pressure hydraulic hose high pressure line with -6AN fittings
CD009 to LS conversion kit - 3000
CD009 Jk40C transmission
Collins adapter
OEM T56 bellhousing
OEM T56 concentric slave cylinder
Gktech v2 shifter assembly
Custom Cd009 to Schassis trans xmember
ISR braided clutch line
ISR remote bleeder block
ISR Wilwood master cylinder S-chassis adapter plate
Custom aluminum 1 piece driveshaft to ABS S-chassis diff
Only looking for trades for 18x11+ 5x120.65 CCW Classics or C5Z T56s
PM for any questions
Stealthyfish is offline   Reply With Quote
Old 09-11-2021, 07:45 AM   #2
Trini-GT
Trini-GT's Avatar
Trini-GT is an unknown quantity at this point
Negotiable on the Accusump?
Trini-GT is offline   Reply With Quote
