![]() Join Date: Dec 2003
1995 s14.5 240sx - SR,Tomei,Greddy,KAAZ,SPL,DMAX
1995 s14 Nissan 240sx s14.5
Does not come with AVS Model V wheels, will be sold with stock 350z wheels. 20K on airlift 3p 18k on KTS coilovers No Trades Location: Oklahoma City Selling so that I can work on my other projects. Info and build List below pictures ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The car is rust free and has a clean title with up to date registration. 120k on the odometer. Fully built SR20det with tons of high quality parts. Bigger injectors and a tune and you can make 400hp. It was previously tuned on e85 and made 354 hp. I changed the car back to pump gas and it is now tuned to 91 octane. Need an alignment which I will have done after the new owner chooses what suspension they want. It has an aftermarket bracket that gets rid of the sunroof mechanism, the only problem with that is there is no drip tray for water that passes the seal. The factory seal is actually made to let water pass through it but the oem drip tray keeps water from entering the cabin. I never drove in the rain so this was never an issue. I will include the oem sunroof and headliner in case the new owner wants to put it back in. Paint is in decent shape but the aero has a few cracks. Car has a dent at the rear passenger door from being backed into in a parking lot (please see pics). No A/C. Comes with a binder full of receipts and product documents. Price is pretty firm. I will part out if my asking price is not met. I will not respond to ?is this item still available. Engine: S14 SR20DET block -Machined sleeves .5mm over -BC rods + ARP bolts -CP pistons 8.5-1 comp 86.5mm -Tomei head gasket -ACL Race main and rod bearings -ARP main studs -SPEC billet flywheel -ARP flywheel bolts -Moroso high capacity baffled oil pan -ATI super damper -Megan Racing aluminum pulleys -Wiring Specialties Pro engine harness -S14 SR20DET Blacktop ECU tuned by RS-Enthalpy (E85, 18psi, 354hp tuned 5/18/19) S15 SR20DET Head -Tomei poncams -ARP head studs -Tomei adjustable cam gear -BC valve guides -Splitfire direct ignition coil packs -ISR upper water neck -Stance upper neck spacer -TF Works aluminum valve cover hardware -Tomei oil cap -Tomei coil pack cover Exhaust -Tomei Expreme bottom mount turbo manifold -Tomei M7960 ARMS turbo -XS Engineering 3" exhaust -Greddy muffler Intake/Fuel -S15 SR20DET intake manifold port-matched 72mm -P2M fuel rail -STI 550cc side-feed injectors -ERA1 72mm throttle body -Greddy front mount intercooler -Greddy FV blow-off valve -ISR intercooler piping -Z32 mass air-flow sensor -Aeromotive stainless braided fuel lines -Aeromotive fuel pressure regulator -Deatschwerks 255lph fuel pump -not installed but included Aeromotive Stealth 340lph E85 fuel pump Drivetrain -S14 SR20DET 5 speed trans -SPEC Stage 1 clutch -Chase Bays braided clutch line -Circuit Sports shifter stiffening kit -ISR short throw -Z1 Motorsports 1pc aluminum driveshaft -Kaaz 2-way LSD -Energy Suspension diff bushings Cooling -Mishimoto radiator -Mishimoto dual fan shroud + fans -Mishimoto hoses -Blitz Type 1 radiator cap -Circuit Sports aluminum overflow tank -Circuit Sports fan controller -Nismo thermostat Suspension/Steering -Gates rebuilt power steering pump -Chase Bays power steering resevoir + lines -ISR steering rack lines -Energy Suspension steering rack bushings -Megan Racing tie rod boots -SPL inner + outer tie rods -Airlift Performance 3 P or KTS coilovers -SPL pro tension rods -SPL toe rods -Cusco upper control arms -SPL traction arms -SPL eccentric lockout kit -GKTech subframe reinforcement plates -SPL aluminum subframe bushings -SPL subframe riser kit -ISR rear strut bar Brakes -Chase Bays brake booster delete -Chase Bays brake bias valve -Chase Bays tucked brake lines -Wilwood master cylinder -Z32 front calipers Interior -Avenue Performance steering wheel -NRG Gen 3.0 quick release -NRG short hub -ISR spin-turn ebrake knob -LRB aluminum defroster vent -AEM boost gauge/controller -AEM Wideband afr gauge -Autometer x Hoonigan water temp + oil temp + oil pressure gauges -3D printed radio/gauge bezel -Nismo shift pattern plate -JEGS aluminum battery box Exterior -Drift Armor front bash bar -OEM S15 headlights pnp for S14 zenki -Custom S14.5 fenders -Silvia Oem S15 hood -S15Origin lab raceline front bumper -S15 core support -S14 Origin Lab Raceline side skirts -Modified Rocket Bunny rear diffuser -GKTech Aero mirrors -D-MAX roof spoiler -D-Max Tail Lights
instagram: madness_garages14 Last edited by mothon; 06-24-2022 at 03:28 PM.. |
