Old 03-18-2002, 12:51 AM   #1
Drift Style S14
Drift Style S14's Avatar
Drift Style S14 is an unknown quantity at this point
How would you go about finding the ideal shift points for a 91 240? is there a formula or something? Oh and by the way does anyone play urban terror for quake 3? if you do want to start a 240/zilvia clan?
Drift Style S14 is offline   Reply With Quote
Old 03-18-2002, 01:26 AM   #2
DuffMan
DuffMan's Avatar
The mathematically ideal shift point is where the ratio of the current gear to the next gear is equal to the ratio of the torque after you shift to the current torque.
Old 03-18-2002, 03:24 AM   #3
Guest
Posts: n/a
well thats just dandy but i can't do squat with out a formula an idea of where to start.
Old 03-18-2002, 10:42 AM   #4
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
I can't give you a precise formula, but the basic variables you will need are a dyno curve, gear ratios, final drive ratio and the diameter of your tires (i think you need this last one).
http://www.vettenet.org/torquehp.html
this article should give you a good idea of whats going on and why gears and torque are good.
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 03-18-2002, 10:56 AM   #5
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
what you want to do is shift so that your next gear lands in your optimal rev range, that's all.
basically, as you rev beyond your peak HP, the HP drops, so revving too far will eventually drop more HP than earlier in the curve, where an upshift might get you.  This means you'll want to know where each gear lands, meaning a shift from 2nd gear at 6500 RPM might mean 4500RPM in 3rd gear.  Once you know these points (you don't REALLY need to know all your gear ratios... all you have to do is drive your car and remember what happens) you can find a general shift point.  A dyno chart would help since it tells you exactly how much power you have at each point, but really you can assume your dyno chart will look like most other 240's...
In the end, I'd say shift between 6 - 6.5k.
AceInHole is offline   Reply With Quote
