Old 02-09-2005, 05:27 PM   #1
d4vech3n
d4vech3n is an unknown quantity at this point
s14 VLSD install
Has anybody installed VLSD from a USDM abs s14 into an non-abs s14? I'm afriad i won't be able to squeeze it in with the drive shaft. I read that it's an option to see if theres enough play to soak up the extra .75" but I have yet to hear of anybody who has done so.
d4vech3n is offline   Reply With Quote
Old 02-09-2005, 08:42 PM   #2
projectRDM
projectRDM's Avatar
You're joking right?
There's at least a few hundred people who have, myself included.
And a few dozen threads discussing it.
FORMERLY R240NA
Old 02-10-2005, 12:39 AM   #3
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
My friend and I just installed a ABS s14 VLSD into my car that doesn't have ABS. The install went smoothly. We just bolt everything in normally, then on the drive shaft, bolt that on then adjusted the support bearing so it can bolt back on its location. You'll understand what i'm talking about when you see it yourself. I heard this only works for s14 driveshaft. o_O
If you have an sr20 and removed the cap at the end of the tranny, then you'll have about .50 of play on the shaft.
driftingisgay.com
nrg is offline   Reply With Quote
Old 02-10-2005, 06:34 AM   #4
d4vech3n
Thanks for the input. I searched every VLSD thread on this board and others and haven't found anybody doing an abs VLSD install into an non-abs s14.
The closest I found was that guy who put in an jdm abs vlsd but swapped the driveshafts as well. And also the write up on www.driftkat.com but he used an s14 non-abs vlsd.
Old 02-10-2005, 08:53 AM   #5
projectRDM
projectRDM's Avatar
Just to make this clear, you do know that a JDM diff is exactly the same as a US diff, right? Not saying you don't, but you mentioned both and I want to make sure you did know that.
FORMERLY R240NA
Old 02-10-2005, 01:43 PM   #6
d4vech3n
I was just being specific so they knew who i was refering to. Anyway, the one on driftkat.com was an non-abs vlsd which happens to be jdm. I don't know exactly how it went with the options in japan but the ratios are slightly different and I guess there were more cars sold that had VLSD but no abs. It's hard to find non-abs VLSD's off s14s here. Every other write up I've seen had people using j30 vlsds.
Old 02-10-2005, 03:29 PM   #7
projectRDM
projectRDM's Avatar
True, but the J30 is identical to the S14, save for a slight gear ratio change. Fitment and install are the same.
JDM S14 diffs have the same ratio as US cars, the only different S14 unit you'll find is in the UK with the outboard diff cooler, the diff case has two ports for input/output of fluid. Otherwise it too is identical.
FORMERLY R240NA
Old 02-17-2005, 10:05 AM   #8
240SXS-14
240SXS-14 is an unknown quantity at this point
Vlsd
I know this is probably a stupid question but how can you tell if you have the VLSD? and what kind of fluid does it use?
I have a 97 240SX SE 5-speed.
Own 97 240SX plan on KA24DET
see my car at
www.modrides.com
240SXS-14 is offline   Reply With Quote
Old 02-17-2005, 12:37 PM   #9
projectRDM
projectRDM's Avatar
It is a stupid question, and it doesn't warrant my time to answer it. You're sitting in front of the single largest source of information the world has ever known. Take advantage of it.
FORMERLY R240NA
Old 02-17-2005, 01:14 PM   #10
Bryants95240sx
Bryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the rough
lol i think that deservers to be in a sig quote
Bryants95240sx is offline   Reply With Quote
