Old 02-13-2005, 02:05 PM   #1
9524tee
9524tee is an unknown quantity at this point
Send a message via AIM to 9524tee
knock sensor ... car runs perfect ... ?
i have a 95 240 with a ka , and the check engine light keeps coming on , when i clear it , it only comes back on at idle for some reason , never when im driving , or have it in gear . just in neutral while idling . this has been happening for 3 years now , and i still havnt had any problems due to it . the car runs perfect . i run 93 octane on a regular basis too , just seems kinda weird . any ideas ?
9524tee is offline   Reply With Quote
Old 02-13-2005, 02:20 PM   #2
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Hello
My 92 s13 had this strange problem where it would lose power nearly every time I drove it. It felt to me like the engine was pulling timing for some reason (although MIL wasn't lit). I diagnosed it and pulled the codes to find code 34, knock sensor or KS circuit error. The error would come right back after clearing, even after a few seconds of idling. I tested the wiring going from the ECU to the KS and found that it had a short somewhere. I bypassed the KS by wiring in a 1 megaohm resistor to the KS pin on the ECU, and the problem (power loss) and code 34 have not returned... You might have bad wiring too?
Just a suggestion... My car didn't knock either, btw, and I always run 91 octane (stupid California)
MELLO*SOS is offline   Reply With Quote
Old 02-13-2005, 08:12 PM   #3
The Hamsterball
The Hamsterball's Avatar
The Hamsterball is making a name for him/her selfThe Hamsterball is making a name for him/her self
Replace the $30 knock sensor ???
White '90 S13 Fastback (SOLD in '07)
The Hamsterball is offline   Reply With Quote
Old 02-16-2005, 09:10 PM   #4
9524tee
my wiring is fine , no corrosion , and it has never been cut . but if you put a resistor on the line , then what is the downside to doing that , nothing ? and also , just replacing the knock sensor wouldnt fix the problem correct ? becuase if it is going off , that obviously means its doing its job ... or am i wrong on that ?
Old 02-17-2005, 05:53 PM   #5
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
not really, if its faulty that means its not working as it should, whether it be triggering when it is not supposed to, or not triggering when it is supposed to, either can happen.
mjjstang is offline   Reply With Quote
Old 02-18-2005, 02:32 AM   #6
vvtisupra
vvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond repute
Send a message via AIM to vvtisupra
where did you get a knock sensor so cheap. nissan wants 130 for it
vvtisupra is offline   Reply With Quote
Old 02-17-2005, 02:07 PM   #7
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Downside is that you don't have a knock sensor so if you run shitty gas or a turbo'd engine you won't have the protection that the KS offers (pulling timing). Replacing your knock sensor will most likely solve your problem, if that is the culprit. I posted what I did because my knock sensor was operational, but the wiring going to it had a short somewhere.
Edit: what code are you getting from the ECU?
Good luck!
Edit: I have had a few people PM me about the knock sensor bypass... Sohere is my post about my KS problems http://www.zilvia.net/f/showthread.php?t=63538 I got my info from a page that explained how to do the process on a 300z, but I've lost that link since
Old 02-18-2005, 02:26 AM   #8
idlafie
idlafie's Avatar
Anything can cause your Check Engine Light to activate...most are emissions-related. Easiest way to try to figure out what may be causing your problems is read the Diagnostic Trouble Code that is kicked out by your ECU. Have you done that yet?? Knock Sensor codes do not activate your CEL...I had a short in my 95 KA knock sensor circuit & always used to kick the dreaded knock sensor code, (DTC 34) and it never activated my CEL. Your problem is something different. Try pulling the DTC's and go from there.
If you need help trying to figure out how to do that, download a FSM from here:
http://www.zeroyon.com/TheSite/techservice.html
This will better help you troubleshoot your problem.
Hope it helps...
ID
Old 02-18-2005, 09:46 AM   #9
mjjstang
^anywehre BUT the dealer
Old 02-18-2005, 10:05 PM   #10
m_haiser
m_haiser is an unknown quantity at this point
idlafie you are a god. free FSM that is awesome. i hope im not the only retard in the group that didnt already have one....
m_haiser is offline   Reply With Quote
Old 02-19-2005, 01:51 AM   #11
9524tee
ok guys , thanks for the info , i will replace the sensor and see what happens , and if that doesnt fix it ... ill post again . thanks , peace .
