Need to get 240 Running!!! HELP
ok, i have a 91 240 5sp. and i have had alot of problems with it lately. At first, It started as after the car would warm up it wouldnt want to start. if it was still cold then it would start fine. but when warm it would just continually crank and smell like fuel. then after a few months of that, now its hard to start all the time. It will try to crank first, then die. then ill do it again, it will start but immediately die. then about on the fourth time, it will stay running but will sputter and hesitate while driving. I really need to get this fixed, please help if you can. i think someone was saying its maybe a leaky injector or something but im not sure. thanks in advance joel
joel wikle |
but if i was getting too much fuel than couldnt that possibly be a fuel injector leaking issue ? what should i do to check the mafs? ive pulled it off and it looks pretty clean in there. thanks for the suggestions guys! keep them coming
joel wikle |
![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
have you changed the plugs/wires/cap and checked the coil? run some injector cleaner through it also if none of those work then pull your fuel rail and look at the injectors
I never knew you could do that with an eggplant |
