Old 03-23-2005, 07:27 AM   #1
l33tmonkeyman
l33tmonkeyman is an unknown quantity at this point
Send a message via AIM to l33tmonkeyman
Angry Subframe Bushing Removal Help!!!
I am in the midst of putting SPL solid aluminum subframe bushings in my car. i got the old bushings out but there is still a metal sleeve in the subframe that has to be taken out. it is really siezed in there with rust. Any ideas with how to get them out?
l33tmonkeyman is offline   Reply With Quote
Old 03-23-2005, 07:37 AM   #2
[email protected]
kuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond repute
The usual way is to make a cut through the sleeve (be careful not to cut the subframe), then use a chisel to bend/peel back the sleeve... you can use a hand saw (slow but safe) or a die grinder (fast but must be very careful, best not to fully cut through the sleeve, do the last bit by hand)...
kuah@splparts.com is offline   Reply With Quote
Old 03-23-2005, 07:38 AM   #3
l33tmonkeyman
i shall try that. hopefully it will work
Old 03-23-2005, 05:51 PM   #4
l33tmonkeyman
welp, i finally have two of them out. just to keep yall updated and how to do it the most efficiently. You first want to get a sawsall and cut a line right down the side of the sleeve. then spread it apart with a lifetime warranty flathead screwdriver or chisel. you should have each out in about 10 min. thanks for all the help
Ryan
Old 03-23-2005, 06:17 PM   #5
silviasichigo
silviasichigo's Avatar
silviasichigo is an unknown quantity at this point
http://www.zeroyon.com/index/content/view/70/47/ Here is a write up of sorts on how to do it. check it out and check out the site. www.zeroyon.com
silviasichigo is offline   Reply With Quote
