Old 04-13-2005, 12:29 PM   #1
Ritz S14
Ritz S14's Avatar
Crank angle sensor wire color? Ka24de
I have a 93 ka24de, and I need to know the wire colors for the crank angle sensor.
I have a few service manuals, but it doens't have the color, nor does it list if it's 1degree or 180degrees.
Once again I need the colors for the 1degree mark and the 180degree mark.
Thanks in advance.
Ritz S14 is offline   Reply With Quote
Old 04-13-2005, 12:49 PM   #2
Ritz S14
Ritz S14's Avatar
Ok. Found this pic
I'm assuming since the black and the white wire are shielded, they must be the 1degree and 180 degree mark correct?
Old 04-16-2005, 12:24 PM   #3
Ritz S14
Ritz S14's Avatar
For those of you who ever plan to install a BEE*R Rev limiter on your s14
Red is ignition
Black is ground
White(optional)-ebrake switch
The brown loop wire is cut for 4cylinder, looped for 6.
Yellow-pin 44/40 is your reference signal(1degree)
Green-41/45 is your 180degree signal.
This was on my s13, I revved the crap out of the motor and the headgasket took a sh1t. So it'll be installed on my s14.
