Old 04-25-2005, 09:09 PM   #1
monkey_man
monkey_man is an unknown quantity at this point
whats a good power source?
whats a good power source to connect the gauges too.... i connect it to the cig lighter for temp.. and all its doing is blowing out fuse by fuse........ so need a new source now. where do you guys connect the gauge too?
(¸.·´ (¸.·´ .·´¨¨°º3 stArRº°¨¨°º
monkey_man is offline   Reply With Quote
Old 04-25-2005, 09:47 PM   #2
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
**************the sun_________,;:=>-+??
MakotoS13 is offline   Reply With Quote
Old 04-25-2005, 09:50 PM   #3
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
the gauge, ah yes, i have the gauge installed as well, its JDM tyte...please be more specific, are you looking to power a gauge, are you looking to power a light on a gauge so it lights up at night when you turn on the headlights?, also might i suggest investing in a multimeter
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 04-26-2005, 07:57 AM   #4
kay_arsen
kay_arsen's Avatar
kay_arsen is on the path to ruinkay_arsen is on the path to ruin
Send a message via MSN to kay_arsen
12v+ Accessory provides 12v+ only when your car is in ACC Mode on the KEY.
This should help
12 VOLTS white + ignition harness
STARTER 1 black/white + ignition harness
STARTER 2 black/yellow + ignition harness
IGNITION 1 black/red + ignition harness
ACCESSORY 1 blue + ignition harness
POWER LOCK orange/black F driver's kick panel To operate, open (cut) the org/blk wire and the doors will lock, pulse the same wire to ground and the doors unlock.
POWER UNLOCK same wire F To operate, open (cut) the org/blk wire and the doors will lock, pulse the same wire to ground and the doors unlock.
PARKLIGHTS POSITIVE red/blue + back of dash dimmer
PARKLIGHTS NEGATIVE -
HEADLIGHT grn/yel, grn/blue + steering column
BRAKE red/green + brake pedal switch
DOOR PIN red/white - courtesy light
TRUNK PIN red - sw. or light in trunk
TACH yellow/red ecm pass. kick panel
LEFT FRONT UP/DWN green, blue driver's door switch
RIGHT FRONT UP/DWN red/white, red/black dr. door or kick panel
HORN green/white - steering column
WIPER lt. green/red - steering column
RADIO 12V red/black + radio
RADIO SWITCH blue + radio
RADIO ILLUMINATION red/blue + radio
POWER ANTENNA black/red + radio
LEFT FRONT SPEAKER brn/wht - brown radio
RIGHT FRONT SPEAKER blu/wht - blu/yel radio
LEFT REAR SPEAKER purple - pink radio
RIGHT REAR SPEAKER red - green radio
kay_arsen is offline   Reply With Quote
Old 04-26-2005, 10:54 PM   #5
Adikt
Adikt's Avatar
Adikt has a spectacular aura aboutAdikt has a spectacular aura aboutAdikt has a spectacular aura aboutAdikt has a spectacular aura aboutAdikt has a spectacular aura aboutAdikt has a spectacular aura about
Send a message via AIM to Adikt
looks like someone used techsoft
Adikt is offline   Reply With Quote
Old 04-27-2005, 12:04 AM   #6
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
on the same note, what's a good source to tap for electric fan if i want it constantly on with ignition?
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 04-27-2005, 07:11 AM   #7
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
I second this, I used a relay and switch for my Ford fan, switch is still in the engine bay, I hate it. Soooooooo, what would be a good ignition on source that will not require a relay.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 04-27-2005, 09:06 AM   #8
projectRDM
projectRDM's Avatar
Safely, there is none. The main ignition to the key switch is the only high current ignition wire in the car, but tapping off of it without a relay may overload the circuit. Then you'll be buying those pretty 45A fusible links every few days. Use a relay, do it right.
FORMERLY R240NA
Old 04-27-2005, 10:11 AM   #9
MakotoS13
MakotoS13's Avatar
i used a $25 painless wiring relay kit from summit racing for my Efan and and i hooked it up to the fuel pump fuse. it works perfectly and doesnt' allow current to flow back into the circuit when i shut the car off. without a relay you'll turn the car off, the fan will still spin, and it could feed back enough current to keep the car alive for a few seconds then sputter, backfire, and die.
not so good for impressing the ladies.
relays are king.
