Old 05-01-2005, 01:39 PM   #1
Carlwill
Carlwill's Avatar
Carlwill is an unknown quantity at this point
Braking in Reverse?
When I brake my car in reverse, I hear a horrible rubbing moan from the back drivers side wheel. When I brake in a forward motion everything sounds fine and normal?
Are the rear brakes only applied in reverse braking?
Linux System Administrator
rm -Vfr /etc/*nix "Love is a fist"
Carlwill is offline   Reply With Quote
Old 05-01-2005, 01:43 PM   #2
Ritz S14
Ritz S14's Avatar
All of your brakes are applied when you apply your brakes. Your brake pads could be rubbing your sensor, inspect, or have someone inspect your brakes.
Ritz S14 is offline   Reply With Quote
Old 05-01-2005, 07:02 PM   #3
91CRXsiR
91CRXsiR's Avatar
91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self
Send a message via AIM to 91CRXsiR Send a message via MSN to 91CRXsiR
since brakes are SOOO important i concur w/ Smog Tech have some1 qualified check em out till then drive proper and brake early
91CRXsiR is offline   Reply With Quote
Old 05-01-2005, 08:57 PM   #4
wakdady
wakdady is on the path to ruinwakdady is on the path to ruin
your rear pads need replaced immediately. I always let my rear brakes go down to the very end. I know they need replaced when they rumble horribly in reverse.
wakdady is offline   Reply With Quote
Old 05-02-2005, 09:48 AM   #5
amolao
amolao's Avatar
amolao is an unknown quantity at this point
Yes theres a good chance your rear pads are gone or pretty close....change them now....dont buy the cheapest stuff from your local parts store..you will get brake dust everywhere around your rims........
http://home.sw.rr.com/longstorenissan ***UPDATED 13 AUG 05 ***
amolao is offline   Reply With Quote
Old 05-02-2005, 10:06 AM   #6
Carlwill
Carlwill's Avatar
Just go to Nissan and get them? I am wondering if my brakes are different from a 240 since this is a real Q's Silvia.
Old 05-02-2005, 01:22 PM   #7
wakdady
yup, they are the same. But i wouldnt bother paying $50 for OEM pads. Just go to autozone or some shit and pay $20. OR, get real pads, i.e hawk,ebc,etc
Old 05-02-2005, 01:23 PM   #8
Carlwill
Carlwill's Avatar
I usually stay away from Autozone cheap crap and just get brand name stuff. I am a firm believer of the, "you get what you pay for.." policy.
Old 02-24-2008, 03:29 AM   #9
mizono
mizono is making a name for him/her selfmizono is making a name for him/her selfmizono is making a name for him/her self
my car does this too, I checked the pads by removing the rear caliper and theres still meat left on the pads. One of the wear indicators was loose so I thought maybe that was the cause of the noise (removed wear indicator), but the sound of metal rubbing is still present when going in reverse and braking.
mizono is offline   Reply With Quote
Old 02-24-2008, 04:03 AM   #10
hustlervibes
Banned from the Marketplace
hustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfection
Send a message via AIM to hustlervibes
I have the same problem where it makes the same noise, but I also still have plenty of meat left. Is yours an S14 too?
hustlervibes is offline   Reply With Quote
Old 02-24-2008, 04:33 AM   #11
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
I have the same problem too.
Gonna take off the caliper & grease everrrrything up
Anto is offline   Reply With Quote
Old 02-24-2008, 06:26 AM   #12
g6civcx
g6civcx's Avatar
When you brake while going forward, weight is transferred to the front end. When you brake going backward, weight is transferred to the rear end.
What you're hearing may not be related to the brakes at all. When you have that much suspension travel in the rear it may be a sign that some other suspension part is groaning.
Old 02-24-2008, 08:48 AM   #13
OBEEWON
OBEEWON's Avatar
Check the bolts on your calipers also, make sure they are torqued down. Ive seen one bolt on a caliper loose causing it to move when brakes were applied in only one direction. Make sure everything is connected correctly and torqued down.
Even a brake place can mess that up so I would double check after you take it to them.
Old 02-24-2008, 09:37 AM   #14
Goldeneye9mm
Goldeneye9mm's Avatar
Goldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura about
Send a message via AIM to Goldeneye9mm
i've got a problem that sounds like yours. my driver side ebrake spring is weak and every once in a while when i back up it doesn't release the ebrake all the way so in moans till i drive it a bit. check the tension on the spring and make sure your e-brake cables arn't sticking. i'd fix mine but i've been broke and for me it's not a huge issue. good luck
Goldeneye9mm is offline   Reply With Quote
Old 02-26-2008, 02:28 PM   #15
SR20d2fourT
SR20d2fourT's Avatar
SR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura about
+1 Same problem w/ my old S13.
My opinion gives me redboxes
SR20d2fourT is offline   Reply With Quote
Old 02-26-2008, 05:23 PM   #16
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
+1 seen this on alot of cars and a truck
xsparc is offline   Reply With Quote
Old 02-27-2008, 04:07 AM   #17
mizono
My car is an s13 and I removed the pads and checked them all and reinstalled them making sure every bolt was torqued down. I know for sure its the brakes, sometimes when rest builds up on the rotors from not driving the car for a while and I go in reverse the noise is present. Its really annoying its probably the design of the s13 rear brakes.
Old 02-27-2008, 04:19 AM   #18
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
ya its a normal thing.
its like viberation from the pad seating its not use to going in reverse i guess. and usually one side is stronger then the other. so it happens.
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 02-27-2008, 07:28 AM   #19
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
This was my problem too. The pads had worn down in the corners of the pads.
Neejay is offline   Reply With Quote
Old 02-27-2008, 02:10 PM   #20
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
its the shifting of the brake pad against the caliper/rotor. when you brake normally the forward motion causes your pads to wear in a particular way (which is why brake shops suggest rotating rotors from right to left, if not directionally vented rotor). When you roll backwards its the brake pad vibrating against the rotor. Get some of the brake lube you apply to the back of the pad and it will cure it.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 02-27-2008, 02:19 PM   #21
Neejay
Neejay's Avatar
Oh, that brake lube stuff works? LOL
