Old 05-08-2005, 11:03 PM   #1
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
weird rumble comming from front wheel area when i brake
just wonderign if anyon ehas experienced this. when i slow down from probably around 10mph and lower i can hear/feel a rumbling comming from infront down in the tire/braking area. i just replaced pads with axxis like a month ago (altho they already squeel. never getting axxis again) and i just had my tension rods upgraded to NAMS ones, other than that i dunno. i checked all the bolts on the brakes and wheels area and they are tight, so im just trying to speculate wut the problem is. anyone got a clue?
redsuns3838 is offline   Reply With Quote
Old 05-08-2005, 11:22 PM   #2
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
how low is the front?
sepulchral is offline   Reply With Quote
Old 05-08-2005, 11:25 PM   #3
JuJuBee
JuJuBee is an unknown quantity at this point
warped rotors
JuJuBee is offline   Reply With Quote
Old 05-08-2005, 11:44 PM   #4
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
warped rotors, possibly bent wheels
i'm assuming you not only kept your stock rotors w/ Axis metal pads, but didnt have them resurfaced when you did so
the metal pads probably caused your old crappy rotors to warp (much hotter temps from this pad) and not resurfacing the rotor cuased the squeal soon after install
get your pads smoothed out and some new rotors (brembo)
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 05-09-2005, 02:12 AM   #5
redsuns3838
my car is pretty low but this happend from way before i lowered the car.
you are correct in that i havent resurfaced rotors and they are stock. i was told it would work fine as a stock brake pad replacement and i wouldnt need any aftermarket rotors or anything =/ thanks guys ill try to get everything fixed and let you know how it goes.
Old 05-09-2005, 01:07 PM   #6
SR240DET
SR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud of
Send a message via AIM to SR240DET
when you turn some times does the rumble go away? if it does... on of your wheel bearings may be bad..... usualy when people describe rumble... i think of the wheel bearing
SR240DET is offline   Reply With Quote
Old 05-09-2005, 02:30 PM   #7
Var
Var's Avatar
Send a message via AIM to Var
i use axxis pads and mine never squeal. I've gone through 4 sets of high temp pads on one set of brembo rotors with a lot of hard mountain driving and smoking brakes. The rotors held up pretty well although i dont think they'll see another set of pads.
Hi
Old 05-09-2005, 03:12 PM   #8
redsuns3838
that might be the diff tho. ur on brembo rotors right? im on bone stock ones =/
how much did ur brembo rotors run u btw.
Old 05-09-2005, 03:18 PM   #9
Var
Var's Avatar
110/pair shipped from ebay. cross drilled and slotted
Hi
Old 05-09-2005, 06:07 PM   #10
JuJuBee
you can get brembos from napa for about 40 bucks each
but as this level...the brand of the rotor doesnt really even matter
