Old 07-12-2005, 03:28 PM   #1
apexi240sx
apexi240sx has made poor choicesapexi240sx has made poor choicesapexi240sx has made poor choicesapexi240sx has made poor choicesapexi240sx has made poor choicesapexi240sx has made poor choices
Send a message via AIM to apexi240sx
s13 S13 Sr20det Idle Misfire, Wierd Humm Noise
Anyone Seen This Problem In Their Sr20det Motor??? Well Mine Recently Started Giving This Problem, It Misfires Under Idle Also When The Car Is In Gear But Off The Gas PedaL. Not Only That It Has This Wierd Humm Noise. When I Drive The Car(under Load) Theres No Misfire... But It Dosent Accelerate As Good. I Changed The Plugs, Gapped Them Corecetly (.35-.32 In.) Also Swapped Coil Packs, Also Messed With The Cam Angle Sensor, But Problem Is Still There. Could Anyone Help??
apexi240sx is offline   Reply With Quote
Old 07-12-2005, 04:03 PM   #2
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
clean your mafs and check your tps voltage
g2ic02 is offline   Reply With Quote
Old 07-17-2005, 03:14 AM   #3
apexi240sx
SR Fixed
i fixed this prob, it was cause i removed the valve cover breather hose to the intake, i had a breather filter on the valve cover and capped off the intake... this obviously threw off the MAFS and caused the engine to misfire, so i put the hose back and back to oil in my hotpipe/intake system .... ( i have to do this cause i have a megan manifold and i cant run the stock oil catch can anymore) so for u fellas wondering to put a breather filter on ur valve cover(sr20det), dont do it unless u have a custom mafs or standalone ecu!!!
Old 07-17-2005, 08:07 AM   #4
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
will it really make that much of a difference, because i dont think a whole lot of air is traveling through it? im acutally having a similar problem.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
