Old 08-08-2005, 06:17 PM   #1
King 240
Banned from the Marketplace
King 240's Avatar
King 240 is making his/her stupidity well-knownKing 240 is making his/her stupidity well-knownKing 240 is making his/her stupidity well-knownKing 240 is making his/her stupidity well-knownKing 240 is making his/her stupidity well-known
Big Brake question
Ok, a friend of mine works for a parts store, that sells Stop Tech brakes. Only reason I'm considering this is the deal he can get.
My question is I noticed that there is'nt a rear brake kit for the 240. I was curious if I got the Z32 rear brakes along with the front, could the Z32-240SX conversion brake lines work?
I will have some 17'' wheels in the front and 18'' in the rear and I would like to fill them up with brakes so just checking.
King 240 is offline   Reply With Quote
Old 08-08-2005, 08:17 PM   #2
Mike Wazowski
Mike Wazowski has a little shameless behavior in the past
Not sure what you are asking, but you may want to upgrade your MC if you are doing a Z32 rear.
Mike Wazowski is offline   Reply With Quote
Old 08-11-2005, 07:51 PM   #3
King 240
King 240's Avatar
Pretty much, I was trying to ask
I know there are big brake kits for the front of the car right. Ok no I've seen big brake kits for the rear, but I can't seem to find a rear big brake kit by the same manufacturer. So I was asking do they just take a front big brake kit and put them on the rear, then modify the brake lines??
Old 08-11-2005, 07:56 PM   #4
IES13
IES13's Avatar
IES13 is making a name for him/her selfIES13 is making a name for him/her self
http://importnut.net/300zxbrakeswap.htm
A rear 300zx rear requires more parts to obtain like the cables, e-brake...
IES13 is offline   Reply With Quote
Old 08-11-2005, 08:29 PM   #5
projectRDM
projectRDM's Avatar
Lines are the same, but the caliper won't bolt up. Front calipers mount on a 100mm flange, rears on 110mm.
FORMERLY R240NA
Old 08-11-2005, 10:41 PM   #6
King 240
King 240's Avatar
Hmm, going out on a limb
If I go 5lug front and rear would a 300zx rear big brake kit work?
Cause I'm sure the connection points of the brake lines are the same as the ones to the car.
So I could get a 300zx rear big brake kit, use the Z32 to 240sx conversion lines and it should work?!
Or am I just
Old 08-12-2005, 09:12 AM   #7
projectRDM
projectRDM's Avatar
Why wouldn't it? Z32 brakes bolt directly to Schassis. So anything that bolts to the Z32 will also work.
FORMERLY R240NA
Old 08-11-2005, 10:44 PM   #8
cheez80
cheez80 is an unknown quantity at this point
alternatively, i think silk road sells a plus sized rotor + bracket for our cars. i remember seeing it on raretrick.
cheez80 is offline   Reply With Quote
Old 08-22-2005, 12:47 PM   #9
King 240
King 240's Avatar
Thanks for your help man.
I think I'm just going to go with a big brake kit for the front and Z32 rear brakes.
Thanks again for the help
Old 11-10-2005, 09:15 AM   #10
importnut
importnut's Avatar
importnut is an unknown quantity at this point
Going that route is probably your best bet. Stop Tech's philosophy is to design a front brake kit, that will compliment the stock rears so that you will save money, as well as have a well balanced setup. Plus, the stock rears are huge compared to the fronts. Oh, in order to make sure you maintain the balance, you will need the Z32 MC.
Good luck!
-Alex S.
"What about the twinkie?"
importnut is offline   Reply With Quote
Old 11-10-2005, 10:52 AM   #11
brainfood
brainfood's Avatar
Trader Rating: (18)
brainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond repute
Feedback Score: 18 reviews
With proper pad choice you dont need to upgrade the rear brakes I have z32 26mm aluminum fronts with porterfield r4s pads (very progressive) and stock rear calipers with rotora rotors and axis ultimate pads it is perfect setup in my opinion the car brakes very well in a straight line and is very easy to trail brake and rotate the car entering a corner. I also have the n/a z32 stock master cylinder because the pedal is kinda squishy without it.
Bryan Rogers
http://www.seriousbadass.com
brainfood is offline   Reply With Quote
Old 11-10-2005, 10:53 AM   #12
Mike Wazowski
^^^Ditto
I plan on running the STOPTECH Z32 14" front kit and STOPTECH Z32 13" rear kit on my S-chassis after swapping for the Z32 upright and e-brake assembly.
This setup has been done before not by just only 1 person and I confirmed it with Jeff Ritter at STOPTECH that it would work as long as you upgrade the master cylinder otherwise your pedal feel and brake bias will be out of whack.
You can even run the STOPTECH 13" 240SX front kit and STOPTECH Z32 13" rear kit and still maintime the proper brake bias (given you have a 17/16" MC) because the piston bores are the same between that setup and the STOPTECH Z32 14" front kit with the STOPTECH Z32 13" rear kit.
